The New GPU 'Merry Christmas' Thread
Shame about them not unlocking, still it would've only been the icing on the cake as you got a bang for buck powerhouse at a price not seen since launch day. :D :cool:
Just stay away from Sleeping Dogs bench until you upgrade that PSU... ;)
The 7990 had crossfire.
I like to think he just reconsidered his stance on a 7990 pwning 290s.
did they, he only had 1 7990 not two didnt he??? I thought matt said he couldn't disable one of his cards to deal with the flickering glitch because of his 7990?? It's not crossfire on 1 PCIe slot though is it even though dual GPU card? educate me
Only dual GPU card I've had is a 4870x2, but my understanding is that as it's 2 GPUs on one card it is crossfire. I believe this is the reason you can only crossfire 2 cards (4 GPU total) where as with the 290s you could crossfire 4 cards.
But a lot of this is guesswork and assumptions on my part.
A 7990 is basically 2 7970's crammed onto one PCB, so it is Crossfire but without the need to use 2 X PCI-E slots
I ran 2 x 680 Lightnings on a 750W and they were fine till giving them some high clocks and that would kill the computer to a shut off.
He should be ok for normal clocks but not sure on headroom.
I wouldn't be taking the risk with that psu like considering how much the components in that rig cost
Head room may be tight, only managed to find 290x gpgpu only power draw figures, on toms it shows worst case scenario each card pulling 295w. So load dependant it could be around 600w just on the cards, 2700k is stock 95w, throw a 50% oc on that and things are getting pretty tight on a 750w unit.
Saying that, I doubt matt will need to overclock either gpu, a silly amount of horsepower at stock, even for 1440 :)
With the stock cooler I don't imagine there's much overclocking headroom, unless you've had a falling out with your eardrums and want to teach them a lesson!
EDIT:
Besides which, with Matt's BIOS editing skills he'll have them tuned and running faster and cooler on less volts in no time!
I will be tweaking for sure, right now im a deer in the headlights. My first time using this new power tune. Going to take me some time to figure out my ideal settings.
Congrats Matt. Santa has been very nice. Look forward to seeing some benchies later.
DPD are being extra slow with my Classi. Not here till 4.30-5.30. Half expecting a call to say "we won't get round to you, too busy".
The first bench is in. No idea if this is a good score or not. No tweaking and no massive cpu overclocks or anything.
