Hi matt ~50-55% fan speed is enough to keep these cards at the rated clock speed. Some things that may be of use. (Most you probably know akready but just incase)
94deg = rated clock
95deg = lower clock
The cards can hit the rated clock at 94deg provided the fan speed has some head room.
My settings for 1 card were:
90deg target
70% max fan.
Its important for powertune to know that it has some fan speed to play with.
Although at these settings the fan will sitt around the 50-55% it wont get near 70% mark in bf4 and will be at the rated clock speed.
I would be wary reducing the core voltage for gaming as the memory voltage seems tied to it and as you found out can cause instability/blackscreen.
With 2 cards you might have a small difference but I did not use a custom fan profile as i didnt need it.
Basically with a custom fan profile if your max fan speed in powertune is still 55 it could be causing a drop in clocks . As even though you have set your fan to increase via afterburner powertune will not be aware of this.
Hope some of this is of help.
See I set mine to 90% in CCC with a max fan speed of 55%.
It hit 94/95ºC, the fan got to about 36% and the cards throttled. Now as far as I'm aware 55 is not the same as 36, but didn't stop it throttling.
I'm not having a go at you, simply that in my experience the default behaviour doesn't prevent throttling and it starts throttling before the fan gets to it's upper limit. Which to me means the system is broken.
I just tried that and i got the same as GM. Fan speed 70% target temp 90C. Temps was 88c and fan speed was 40% and as soon as it go to 90c it was throttling and fan speed was around 43%.
No problem im just giving some info of my experiencd and what caused conflicts with powertune. Powertune and afterburner dont seem to work well together. Snd sometimes even though the power limit says +50% in afterburner it could be 0 in powertune.
Yes this could be the issue. However id rather use afterburner and lower voltage than use CCC and use a higher fan speed.
