What OC?
7990 looked sexier!
I know. I was just wondering what Dg was on about![]()
So what we're saying is, with that vent that seems to be the cause of this issue, not only does the AMD reference cooler not actually cool as well as we'd like, but it also doesn't totally do the 'blower' thing of exhausting all the hot air out the back of the PC?
Did you try blocking the side vent up on the cards?
On a side note (as I doubt it'd help with this), I wonder if changing the thermal paste would help temperatures much?
Common then matt, give me a water budget to work with and I'll get waving my magic wand (giggidy).
I have ordered some Gelid Extreme.![]()
I'm trying to remember if my reference 7970 had that vent, i think it might have.
By the power of Petey:
Doesn't seem ideal in a blower cooler to me.
Am I right in saying that with OcUK I can remove the cooler on a Sapphire card without voiding warranty?
Question Matt, are your temps the same if your case side is off or are they better?
If they're better with the case off, there must be something you can do to optimize.. Let's think, what else do you do on the 25th of December.![]()
