if i sell my 7990, what should i replace it with?
22 Nov 2010
Kettering
hey guys,
as prices have shot up and people are snapping them up, i may sell my 7990, but, what do i replace it with? i want at least the same amount of performance.
GTX 770 SLI?
R9 280X CF?
GTX 780TI?
what do you think guys?
i will get the GPU's from the MM, so i should be able to pick up two of the ref design cards (hope so anyway)
im using a 144hz monitor so more FPS the better :D
Most likely better value, depending on the price of a 780 of course. You could always pick up one now (290), or wait for the non-reference coolers.
780s pop up in the MM more often (dont think non X290s have shown up yet?) so if you're going to buy second hand, 780s might be your most viable option, they go for pence now as well :)
is there a certain 780 you recommend? my 7990 hits 80 in bf4 atm so two 780's that could be quieter and cooler is a huge+ to me
im running a CHFZ in a cm storm trooper, yet its ok but gets noisy when it srarts to get pushed.
could you tell me the pros and cons on the 780 and 7990?
I play bf4 mostly but play a lot of others as well.
How much are 780's going for in the mm atm? May be able to pick two up for SLI.
