Galaxy Tab 3 7inch - thoughts please
Asus Memo Pad 7" - £59
Galaxy Tab 3 (7") - £79
Nexus 7 (2012) - £99
The Memo Pad wins hands down at that price, I wouldn't even consider the other two.
I wouldn't consider the Memo Pad. Crap screen and crap processor when compared with the 2012 N7.
Yeah it's cheaper, but it's for a reason.
Are you sure about that? Have you used the memo pad or are you basing that from online reviews because although I did own the n7, I've read the memo pad is almost identical, both are made by Asus, but the n7 feels a bit more premium and the memo has a memory card slot.
Think you might be confusing it with the older Memo Pad mate. The £59 on offer is the ME137X, very similar to the 2012 N7.
Just picked mine up now, and yep it's the 16GB Asus Memo Pad HD7 (ME173). Cost £59 which is a bargain. I just need a cheap 32gb card for it now and then I'm sorted.
You can't get a memo pad for £59 anymore though it's out of stock and the 5 day special deal will most likely expire before it's back in stock..
That leaves the nexus for 99 pounds as the best option.
Picked up 2 of these from CPW yesterday, one for myself and one for the better half.
You can still pick them up at £69 instore though, picked one up at my local Tesco today and they had plenty of stock.
Even at £69 it's a bargain. I was using mine last night and it is just as good as the original N7, except this also has a memory card slot. The build quality and screen are really good in my opinion. Does anyone know of a car mount that holds a tablet of this size?
