Caporegime
- 13 May 2003
- Warwickshire
Hi all
In a nutshell, my problem is that my BIOS has the Intel controller set to RAID as I'm running two HDDs in RAID0, but my Samsung 840 SSD is not running in AHCI. I understood that RAID would enable AHCI on the controller where possible.
My mobo is a Gigabyte P35C-DS3R with the latest F12 BIOS. It uses the Intel ICH9R southbridge, which definitely supports AHCI. I see a message saying "AHCI BIOS not installed" when I boot up, which I'm assuming is the reason for my whole problem.
Samsung Magician won't recognise my 840 as being in AHCI mode, nor will it recognise the SATA interface...
...yet Intel RST states that I'm using NCQ:
How can this be, when I understood NCQ to be an inherent part of AHCI? If both are correct and AHCI is not working but NCQ is, then do I really care if AHCI isn't running?
My AS SSD benchmarks seem all right for a SATAII controller:
So maybe it doesn't really matter? But I have no AHCI controllers referenced in my Windows device manager, and it's slightly bugging me that I could be running in AHCI but aren't.
Maybe there's a problem with this particular chipset running RAID and AHCI at the same time on the same controller? Should I just try the SSD on the Gigabyte controller and see if AHCI works?
Thanks.
Thanks.
