- 8 Jan 2009
- Northern Ireland
I have win8, and wanting to get to 8.1. Is there a update I need to download before it appears in the store.
That link took me to the store, but no link is showing. So I downloaded kb2871389, and it said I already have it installed. Im running win8 OEM preinstalled, don't think that is the problem.![]()
Have you rebooted your PC since the last updates?
yes, got my updates on tuesday.
However, some folks are having a hard time actually finding the update itself, so let’s help them. If you can’t see Windows 8.1 in the Windows Store, you probably need to run Windows Update to get the “KB 2871389″ update. To do this, follow the directions here. This appears to be the most common issue.
managed to get it by, uninstalling that kb2871389, then reinstalling the kb2871389 manually.
Maybe you had a corrupt KB2871389 install first time round.Quote:
