Beast Rig
25 Dec 2013
So after a lifetime of subsisting on prebuilt lower mid range PCs and running stuff at 20 FPS I finally worked my ass off long enough to get a top of the line custom machine.
I am basically set on the CPU, RAM and Graphics Card (tho I am willing to consider different models of the 780ti as I am not too sure what exactly the difference between them is).
Would appreciate any advice on the other parts to either improve performance with a small increase of cost or drop the cost without any real impact on performance so i can maybe buy some food in January. ^^
So here are the parts so far:
Case
Cooler Master Cosmos II Ultra Tower Case - Black
http://www.overclockers.co.uk/showproduct.php?prodid=CA-249-CM
Motherboard
Asus Z87-DELUXE Intel Z87 (Socket 1150) DDR3 ATX Motherboard
http://www.overclockers.co.uk/showproduct.php?prodid=MB-568-AS
CPU
Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - OEM
http://www.overclockers.co.uk/showproduct.php?prodid=CP-473-IN
CPU Cooler
http://www.overclockers.co.uk/showproduct.php?prodid=HS-002-BQ
Be Quiet! Shadow Rock Pro SR1 CPU Cooler
Graphics Card
EVGA GeForce GTX 780Ti Superclock 3072MB GDDR5 PCI-Express Graphics Card (03G-P4-2883-KR)
http://www.overclockers.co.uk/showproduct.php?prodid=GX-233-EA
RAM
Kingston HyperX Beast 32GB (4x8GB) PC3-19200C11 2400MHz Quad Channel Kit (KHX24C11T3K4/32X)
http://www.overclockers.co.uk/showproduct.php?prodid=MY-131-KS&groupid=701&catid=8&subcat=817
SSD
Intel 530 Series 180GB 2.5" SATA 6Gb/s Solid State Drive (SSDSC2BW180A401)
http://www.overclockers.co.uk/showproduct.php?prodid=HD-040-IN&groupid=701&catid=2104&subcat=1427
HDD
Western Digital Caviar Black 2TB SATA 6Gb/s 64MB Cache - OEM (WD2003FZEX) HDD
http://www.overclockers.co.uk/showproduct.php?prodid=HD-410-WD
Optical drive
LG BH16NS40 16x SATA Internal BDRW - OEM
http://www.overclockers.co.uk/showproduct.php?prodid=CD-116-LG
PSU
Corsair RM Series RM 850 '80+ Gold' 850W Power Supply (CP-9020056-UK)
http://www.overclockers.co.uk/showproduct.php?prodid=CA-155-CS&groupid=701&catid=123&subcat=2466
You've got quad channel RAM there; your motherboard supports dual channel, so get two 16gb kits (if you really need that much RAM) or go Ivybridge-E instead of Haswell.
The motherboard is expensive. Is there any particular reason you chose it?
Post your budget: some of the General Hardware locals will have some fun with it ;)
EDIT: Speak of the devil...
Also I believe some people have been having problems with that PSU, maybe get a Superflower alternative :)
Picked the motherboard because it was the cheapest in the high end system builder. ^^
That is a component I really know quite little about, so I would be fine with a cheaper one as long as it does not impact gaming/editing performance.
I'm fine with changing most parts as long as there is no real impact on performance or reliability.
As far budget goes, i would really like to keep it under 2100, which this thing so far fails to do. Ideally it would be about 1900 - 2050.
Part timer? You're like an old sage who comes down from his mountain retreat to impart his wise counsel whenever someone has over £1500 to spend on a new PC.
:eek: I do pop into cheaper builds as well ...... given that I never stay on budget but that's another story :p;)
I will just leave this here then ....
YOUR BASKET
2 x EVGA GeForce GTX 780 3072MB GDDR5 PCI-Express Graphics Card (03G-P4-2781-KR) £395.99 (£791.98)
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £245.99
1 x SuperFlower Leadex GOLD 1000W Fully Modular "80 Plus Gold" Power Supply - Black £155.99
1 x Corsair Carbide 540 High Airflow ATX Cube Case - Black (CC-9011030-WW) £129.95
1 x Gigabyte G1.Sniper Z87 Intel Z87 (Socket 1150) DDR3 ATX Motherboard £119.99
1 x Corsair Hydro H100i High Performance Liquid CPU Cooler (CW-9060009-WW) £99.95
2 x Avexir Venom Series 8GB (2x4GB) DDR3 PC3-17200C9 2133MHz Dual Channel Memory Kit (AVD3U21330904G-2CIG) - Green Light £79.99 (£159.98)
2 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £76.99 (£153.98)
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £65.99
1 x BitFenix Alchemy Cable Bundle - Green £28.45
1 x Samsung SE-S208DB/TSBS External Slimline 8x DVD-RW (TV Connect) - Black £21.98
6 x Alpenföhn 120mm Wing Boost Shamrock PWM Fan £14.99 (£89.94)
1 x BitFenix Alchemy 8pin PCI-E extension 45cm - Green £6.98
1 x BitFenix Alchemy 6pin PCI-E extension 45cm - Green £6.49
2 x BitFenix Alchemy SATA 6GB/s braided cable 30cm - Green £5.99 (£11.98)
2 x BitFenix Alchemy Molex to 3pin x3 Fan adaptor 7V 20cm - Green £4.99 (£9.98)
1 x BitFenix Alchemy Internal Audio Extension Adaptor 30cm - Green £4.49
4 x BitFenix Alchemy 2pin I/O extension 30cm - Green £3.95 (£15.80)
Total : £2,141.29 (includes shipping : £17.85).
Case + cooler
http://www.overclockers.co.uk/showproduct.php?prodid=WC-025-TL&groupid=2180&catid=2723
Mb
http://www.overclockers.co.uk/showproduct.php?prodid=MB-434-GI&groupid=701&catid=5&subcat=2574
Ram 16gb as you mention editing tho could save £50/£60 with 8gb kit as is good amount for gaming, 32gb is overkill for 99% of usage
http://www.overclockers.co.uk/showproduct.php?prodid=MY-046-TG&groupid=701&catid=8&subcat=1387
Psu 650w good for single GPU, if planning sli/xfire go with 850w. I've chosen seasonic tho current poster child seems to be the superflower
http://www.overclockers.co.uk/showproduct.php?prodid=CA-027-SS&groupid=701&catid=123&subcat=2383
GPU 780ti overkill unless going for high res gaming(3x monitors or 4k), 780/290 good for upto 2560x1600 res
Ssd
http://www.overclockers.co.uk/showproduct.php?prodid=HD-168-SA&groupid=701&catid=2104&subcat=2394
Edit: damn a few replies while I was typing especially from the 'modmaster'.
Add the orange psu extenders for the ethermaster touch :p
Ok, thanks for the builds!
Looks like everyone is suggesting a dual graphics card build over the 780Ti.
So far I'm leaning towards the build of Mr Doomedspeed. :)
Just need to add a proper Blu-ray drive tho.
Was also wondering about the Corsair Obsidian 750D case and how good the dust filter on it is. My place is dusty as hell so I need something solid for that to keep my rig from clogging up in a couple of months.
Doomedspeeds is the same as mine just white ;)
Why do you need an Blueray drive?? I use Sky "NOW" box office or netflix and not touched a disk in years ..... apart from today to install Windows XP on my sisters netbook.
