I found it surprising they get beaten by an i3 but it defo made me lol.
Can't understand why anyone would take the 8350 over an i5.
How about because it has more cores so when all of those cores are maxed out it will be faster?
It depend on which i5 you are talking about. It trade blows with the Haswell i5 on the same clock speed when all cores are used that's about it; when not all cores are used (which is vast majority of the situations), it's slower than the i5.How about because it has more cores so when all of those cores are maxed out it will be faster?
In BF4 benchmark it clearly shows the FX8 is only equal to the Sandy i7 comparing at same clock, and Sandy i7 is more or less on par with Haswell i5 which has higher IPC.In well threaded games like BF4, the FX 8 core pulls away from the Haswell i5 and performs similarly to the i7 4770k (both overclocked).
Nobody is doubting the value for money of the FX8320, but some people would still go for i5 purely because the CPU demanding games they mostly play don't use more than 4 cores (i.e. mmos, strategies, simulators etc).
If you want to talk about "real world", then you wouldn't be quoting 5GHz on the FX8 considering it require both the combination of winning the silicon lottery and using one of the more expensive boards. Realistically, average overclocking for the FX8 is only around 4.60-4.80MHz for most people on everyday use.Why would you compare the same clock? We know the Intel CPUs have a higher IPC. Compare achievable overclocked levels. FX CPUs easily reach 4.8/5GHz and at those clocks are comparable in BF4 performance to the i7 4770k at 4.4/4.5 GHz (again an achievable overclock for most).
I'm talking real world comparisons which is what is important to people.
I get what you are saying, and pretty much agree with everything you said there...except may be the FX8 "obliterating" the Phenom II X6 partSlightly off topic, but...
Depends on the situation, i have a Bloomfield i7 running @ 3.9Ghz which destroys a Haswell i5 @ 4.4Ghz in 3DMark Physics tests.
I think the Haswell i5 might beat it in integer performance, encoding, compression ecte... all that stuff the FX-83## is good at. But FP performance Intel's seem to have changed little, and AMD, only less so, adding more cores certainly has the FX-83## obliterating the P-II x6.
For Games, overclocked vs overclocked performance i'm probably better off with the BloomField, the frustrating thing for me is my only upgrade path from a 6 year old CPU is an Ivy or Haswaell i7, thats £400+.
IMO on both sides the latest CPU offer little in terms of gaming performance gain.
Enthusiast CPU level upgrading has completely stalled over the past few years.
While the FX8 certainly give more performance for games that use more than 6 threads, for most part it doesn't make that much of a different, particular for games that don't use more than 6 threads
As for Haswell i5's overclock, most people settled on 4.50GHz because any higher in voltage the temp would be too much, however that would not be an issue for those that delid the CPU and removing the crappy heat trapping sealant (dropping the overclock load temp by up to 19C). With a semi decent board, 4.60-4.70GHz is totally doable.
And speaking of real world, the probability of games using 8 threads "fully" is by far lower than games that use less than that. So far only games by EA and Ubisoft are "heading toward" making using 6 threads+ for games as standard, but the rest of the developers in general are still stucked using game engines that don't use more than 4 cores.
Sorry to jump in to argument, I had plan for fx 6300 however by seeing i3 3240 results. which one do I go for out of this two as they are the same price.
What'd you get on the Bloomfield in Firestrike Physics Humbug?
I get what you are saying, and pretty much agree with everything you said there...except may be the FX8 "obliterating" the Phenom II X6 partWhile the FX8 certainly give more performance for games that use more than 6 threads, for most part it doesn't make that much of a different, particular for games that don't use more than 6 threads
I honestly really looking forward to what AMD has to offer for their next CPU lines, and how it stands again Intel's offering as well.
If Intel still only offering 4 cores with no HT for under £200 for their new product lines in 2014/2015, they can seriously GTFO9630 @ 3.9Ghz
I'm not holding any hopes for AMD and better gaming CPU's, i don't even think they are interested in replacing the FX-83##, not for at least a year, if ever.
I'm hoping for a sub £200 CPU from Intel that will actually make a worth while upgrade.
If Intel still only offering 4 cores with no HT for under £200 for their new product lines in 2014/2015, they can seriously GTFO![]()
Except both you and I know it is not going to happen...look at the pitiful increase over the last few gens...they have already starting to hit a brick wall on bumping IPC. If they are only able to do 5-10% bump again, adding more cores would be the most straight forward way to increase performance for end-user, rather than keep trying to squeeze a few drops of blood from stone and call it an upgrade.What a stupid thing to say.... Stop getting caught up with the silly core count race..
If Intel can offer 4 cores with no HT that annihilates 6 and 8 core CPU's then they can take my money.
