Looking for an oven/meat probe.
Thermometers arrived today, the oxo and the blumenthal.
The oxo reports and confirms my oven is mince. The 250 setting is really 220. 30 degrees is a lot!
When my oven light went out to indicate it was upto temp, it was actually 40 degrees off. The oxo does seem slow to respond however, so I won't take that as gospel.
Yet to try the Heston for cooking. Tested my coffee however and some boiling water. Seems accurate enough and I can confirm for anyone else interested it is the updated model with user programmable temps.
Just waiting on the thermapen now.
Good to know but not surprising at all /re how inaccurate the oven is sadly.
At least you now have the knowledge to work around it as best as possible :)
Exactly, I knew it was off. That's why I bought the thermometer in the first place. I've now remarked the oven with a sharpie. Sorted!
Right, the oven was set to 200'c the first image is when the thermostat switched off.
The second image in when the oven reached 200'c.
So my oven is pretty accurate at 200'c.
Your ovens a show off!
I never thought to stick my probe in the oven!
Not a euphemism, honest. :p
@OldCoals
Definitely a good sign for 200C. How is it at other temperatures? Have you also tested that probe at 0C and 100C? I'm not trying to make things look bad - just interested if you've lucked out and got an oven that happens to be extremely accurate :)
There is a video in this thread of me boiling water, the Heston probe and the CDN one both registered something like 99.7'c for the water.
I have the revised heston probe and did a leg of lamb. When it reaches temp I can't seem to shut the beeping off. Does it beep forever!
