Will you be drinking to that? *sigh*
No, but I shall be looking to start a thread enquiring for advice on what to do about a girl in the next half hour or so. Stick around, it should be fun.Will you be drinking to that? *sigh*
You could do worse than one of these:=
http://www.ebay.co.uk/itm/Apex-Char...plies_Office_Furniture_ET&hash=item5af3001646
Was thinking the same thing lol.
Avoid chairs from the likes of Ikea, the Markus gets mentioned a lot, but all chairs of that ilk (ie. cheap but with good looks (like a cheap hooker)), end up with padding that's as flat a pancake after a short period. Does the back of the Markus even have adjustable tilt?
No chair for £100 is better than the chair you just bought, nor is it any better than a £20 Argos chair.
Spend £200 plus and get a chair that makes you sit right and reclines properly.
As suggested get a second hand Steelcase leap, total comfort and will last forever.
They look strong....but are they comfy
High end chair? £80? Lol! You couldn't get any cheaper
B@
Ikea MARKUS is the best chair you can get for £125
I'm not sure why you hate the Markus so much, I've had mine for four years now and it gets used a lot (computer, watching TV, games consoles... even work) and I'm only just thinking about replacing it. The back is adjustable and it's still perfectly comfortable.
Love my Obutto seat more than I thought possible, costs a fair bit but it's by far and away the most comfortable thing I've sat in, has all the right support for your back, fully reclines and plenty of padding. Feels like a much better seating position too than a standard desk. The only thing really is the lack of armrests, I have a couple of £10 ebay specials to mod onto my pit but to be honest I've not felt the need yet.
