Some games will still drop below vsync... Crysis 1 is a pain in the ass for it...
IIRC Crysis 1 only uses 2 cores. So it will drop below 60 no matter what CPU you use.
i5 is fine with any single current card.
The 780 has been out for too long to be worth considering.
Crysis 1 isn't the only game that only uses 2 cores...
You'll need more clock speed on your 2500k.... At least 4.6Ghz
I only run my 3930k @4.0 gaming with 4 Titans lol.
Most of the time if people have to run at speeds higher than this it has more to do with multi player games or rubbish software like Crysis, neither of which has anything to do with GPUs.
Nice to see you on here, Purgatory.![]()
Is a GTX780 overkill for the below system. The i5 2500k is clocked at 4.2. I have the upgrade bug and fancy a new GPU.
I thought about upgrading from a 470 to a 780 ti to game at 1080p. I am wondering through if the ti is really worth the premium for that resolution and to stick to a 780. I do like everything cranked up on max though and looking pretty! I'm also running an i5 760.
Thanks mate nice to see you're still about on the forums, happy new year.
I keep thinking maybe I should wait until Maxwell, which may be in the next few months (or not!).![]()
Crysis 1 is so badly coded it shouldn't even be used for benchmarks and especially a game that is now 7 years old
