And humour me... what are you supposed to do when it starts to slide?
Brace for impact
In an mr2? Steer into it, keep on the accelerator (assuming you've lifted off) and pray.
In a fwd car, keep your foot in it and steer in - tbh though until its happened to you a few times you will likely over correct unless its at very low speed
are you sure its meant to have 185's fitted? find out if its meant to have 195's (they are wider and have more grip).
and if you want some grippy tyres, continental premium contacts are really good in the wet and dry.
yea those tyres are poor but should still hold a focus on the road if driven normally
knowing what my car drove like with over inflated rears i would definitely be blaming that high pressure + lift off oversteer + greasy road
Shall do. I guess it's not worth scrimping when I could have a smash due to junk tyres.
This is a bit of a misconception, wider tyres don't offer greater grip as their are a lot of factors involved such as contact patch etc.
Depending on the weight of the vehicle you can actually reduce grip with wider tyres, then there are things like slip angle.
[TW]Fox;25604390 said:No, it cannot. There is absolutely no reason why the rear end of an FWD car driven completely normally in normal non-extreme conditions with quality tyres all round and good condition suspension should 'sometimes just' step out.
There must be some sort of issue with the car - I'm going for crappy tyres on the rear.
