**Official 3DMark 'Fire Strike' Leaderboard**
Sounds like an escort to me :o
JK JK!
:eek::eek::eek: How dare you!
:D:D
The Mrs is cooking in the other room at the moment and it's getting warm in here. :D lol.
I'm having an issue in Heaven and Valley where the power limit will die and sit at 67%. Really annoying. On Skyn3t BIOS for what that's worth. Not sure if that's OCP kicking in or what as I've set power limit to 130% anyway even though I doubt I'd exceed 115% at a push
Sounds like a power throttle - set your power to max :D
Which PSU do you have?
Single or multi rail - if it's multi rail, that will more than likely be your problem
Just checked your build log - 30Amp on each rail.
I had the Enermax 1350 and had the same issue your describing.
Your not using the dual PCI-E 6+2 pin cables?
Superflower 1200w matey. Single rail, a mahoosive one at that lol. It's stopped doing it now although I wacked PT up to 160% and rebooted so... ;)
I am using the dual cables aye
http://www.3dmark.com/3dm/2144925
a warm run in a warm room...stay tuned ;)
How is this even beating me -.-? Lower physics, lower graphics, higher combined? WHY? I call H@X :o
Glad your sorted - look forward to some good scores :cool:
A few on OC.net have had issues using the dual cables (just a heads up :))
