- 18 Mar 2010
I think most goods are pretty much the same size these days, apart from obvious variations in height and small variations in depth for washers.
Anyway, it's nothing a tape measure could have told you.
If you ran it, did you run it with anything in it at all - detergent, clothes? If not, then you might get away with it.
The measurements given by currys are not totally accurate, they dont give any account for the fact that you must have a cold fill pipe sticking out the back which adds ~2cm. We are about 1cm from it being ok!
