System Specs
[email protected]
16GB DDR3 2133Mhz
2x290 Pro Crossfire
Win 8.1 64Bit
1440P Resolution
Games - Ultra-Highest Preset & AA/SSAA Settings Used
Dirt Showdown - MSAA x8
Metro2033 - MSAA x4
Tomb Raider - SSAA x2
I ran three gaming benchmarks to see what performance boost a 30% overclock on the memory would give a couple of AMD 290 Hawaii cards. Is it possible to increase the performance of the 512 bit bus over stock, or is it already delivering more than enough performance? At stock the bus delivers 320gb of bandwidth. Overclocked it delivers 416gb of bandwidth.
1250mhz Testing - Settings
Results
1625mhz Testing - Settings
Results
Conclusion
Dirt Showdown Minimum: 0.6% increase from overclocking the memory
Dirt Showdown Average: 2% increase from overclocking the memory
Metro2033 Minimum: 10% increase from overclocking the memory
Metro2033 Average: 2.3% increase from overclocking the memory
Tomb Raider Minimum: No improvement 0%.
Tomb Raider Average: 0.8% increase from overclocking the memory.
Overclocking the memory has very little effect on Hawaii as not many games are capable of saturating the bandwidth that the memory and 512 bit bus offers, at least at 1080P/1440P. I would expect memory overclocking to have more of an effect at Eyefinity or 4k. Outside of synthetic benchmarks overclocking the memory is almost pointless for Hawaii users who should instead stick to overclocking the core for the biggest gains. According to my testing memory stability and overclock potential is strongly tied to core voltage with Hawaii. As you can see overclocking the memory to 1625 required me to increase the voltage from -0.050mv to +0.100mv to ensure stability and no black screens. I can probably lower the voltage a tad, around +0.075v or slightly higher should be enough for me if i wish to keep that ridiculously high memory overclock/bus bandwidth.
I might add/test some more games in due course. I also welcome testing from other Hawaii 290 users to see if they find something similar.
[email protected]
16GB DDR3 2133Mhz
2x290 Pro Crossfire
Win 8.1 64Bit
1440P Resolution
Metro2033 - MSAA x4
Results
Results
Conclusion
