The radeon 5450 is a good shout, I use a 6450 with good effect.
Whats the major difference between the two? I assume the 6450 is newer? Is it better?
Just make sure it has a thin cooler on it
How thin exactly? Would something like this be OK?
Make sure it comes with a low profile bracket, the Asus 5450 above doesn't come with one according to the info.
Can't the 6450 do something the 5450 can't do? Something like 3D blu ray?
Yes, I did exactly this a couple of months ago (from an N36L to an N54L).Hi Folks.
Ive just picked up a HPN54L to replace my HPN40L. Can I just swap out the disks including the OS drive to the N54L to get it going?, Ive got 2 3tb drives in raid config and a 3tb as a general drive and the 250gb that serves as my OS drive.
Probably a long shot but can anyone recommend a USB freeview tuner which can be recognised when passed through in esxi.
My google skills are lacking here some saying one works however others saying it doesn't, all I really want to be able to do is record some shows and I haven't got a prefence on which OS or application to use either.
UnRAID... it's a halfway house between proper RAID and JBOD that still provides some redundancy, and suits your mismatched drive sizes perfectly - you can use any combination and number of drives, the only condition is that the parity drive (one drive, similar to RAID-4) must be the same size as the largest drive in the rest of the array
USB pass through works pretty well, I can't imagine why it wouldn't work. Passing through pci cards won't work but usb should be fine.
I'm looking to get one of these microservers while there is still cash back available, I was wondering on what operating system to put on it either on SSD or USB with the following hard drives that I will put in it: 2x 3TB & 2x 2TB.
I currently have a Synology NAS with the 2x 2TB installed which are acting as JBOD as I wanted to maximize my available storage space, but now I need to expand so got the two 3TB's as well. My plan was to put the 3TB's in the microserver as well as the 2TB's and sell the Synology.
I don't think I would be able to get any kind of RAID configure going with that kind of combination of hard drives as I know they need to all be the same size, so I think I may go down the JBOD route again and perhaps in the near future attach an expansion unit for possible backup, so with that in mind if anyone has any recommendations for the operation system that would be great!
