Full frame and a 35mm prime = Dof even at f8![]()
It's like magnets?
I have a bunch of those in various sizes, someone send them to me from NZ years back, they don't do anything that I can tell.
HOWEVER, this is a big however, I notice some of the OEM power cables from normal everyday components have those actually "built" in, I've seen them, it's just a black plastic thing that looks like a kind of supressor at the end of the cable. These are not even hifi components, I think I've seen them in like £35 Logitech 2.1 speakers systems, and where companies makes no big claims on these things. So part of me wonder why they add it in if they don't do anything.
Still on sound... anyone know best place to get 3.5mm to 3.5mm decent quality cables? Ones with my headphones are properly sack.
I suggested the v-Moda cable because I saw this review (it's on Youtube), on the Philips X1 and the guy actually got a Ohm meter out to test the cable the X1 came in, /mumbles a bunch of maths, and basically the Philips cable has a high resistance and he recommended the v-Moda cables as they have a very low resistance, any sonic benefits aside, they work and they are not expensive either.
[/QUOTE]
Big thumbs up. :)
Quite a close focusing distance on that. Was going to stand 2 rooms away and use my 300m f/2.8 for the same effect![]()
^ "Wonderful, wonderful."![]()
Big thumbs up.![]()
New bag and wallet from scaramanga. Not heard of the site before but the bag is excellent really well made and solid. It is the large overland bag so I can fit my laptop in.
I have only ever seen the original 80s tv series, so loooking forward to seeing this![]()
[/QUOTE]
Awesome series but I would say to also get yourself [URL="http://www.amazon.co.uk/Battlestar-Galactica-Edward-James-Olmos/dp/B009ERSHL4/ref=sr_1_1?s=dvd&ie=UTF8&qid=1389800994&sr=1-1&keywords=the+plan"]The Plan[/URL] as it's not included in the set
