Overclocking - Is it worth it?
Not really bothered too much with it so far with the 780 but it does have a pretty big boost over stock out the box.
My 470s I ran clocked - the increase from 607 stock to 800MHz was quite worth it :D especially with 2 of them in SLI - would go further than that even but the noise and heat went up to a whole new level above 800MHz.
I run my sli 780s stock for gaming as every game I play is 100 plus fps no need to shorten the life of the cards for a extra 20 fps I don't need.
Overclocking the gfx is good fun for a benchmark or 2 it passes a morning when you get new cards but once the benching is done its back to stock and game on.
+1
Overclocking is worth it, when you really need the extra 20% FPS. That being you've turned settings down to min and you still need them :D
Never really bothered with the whole overclocking 20% so i can run higher ingame settings, or keep highered settings to maintain a better average clock, i tend to mostly run stock/boost clocks and turn settings down...but that's me! :p
Always have my CPU overclocked, normally to 4.0 or 4.5. (4770k was the exception, as it was bought as preoverclocked to 4.6 :D)
I have my 3930K clocked at 4.625Ghz 24/7 and the beauty is, it is done in the BIOS, so no need to bother with loading up software to run the clocks. I don't like having programs loading in start-up, as I like to keep that as clean as possible. If we could do the same for a GPU, I would set and forget... Maybe one for the nVidia/AMD peoples to sort.
Nicely done Greg.
I stick the 780s at 1200MHz on stock bios now. Especially is watercooled, this gives max temps of only 39/40C after hours of playing so no reason not to really.
Its always nice when you get a couple of cards, new CPU etc.. and just do a bit of benching to see what they can achieve, I bought the components a while ago for cranking things up a bit but everything seems to run ok @stock just now, except Cod Ghosts which runs like a bag of nails for a lot of dual card users.
Stabiltiy is key. No OC is worth constant BSODs. My GTX670s are factory OC'd but no more and they run at sensible temps. 3930K is OcUK OCd. The last time I actually OC'd something myself was an AMD4000+. Yes I'm lame but stability is the most important factor.
If you are just shy of the frame rate you are looking for it can definitely be worth it though. But it's often a hint that a new purchase will soon be required.
FWIW: RIVE + 4.4GHz 3930K 2x EVGA 670 FTWs
If I was running a 60Hz monitor then I probably wouldn't bother too much since you can't see the benefit pushing past 60FPS. 120Hz is different story however :)
Most of the time l don't OC my SLI 670's when my CPU is OC'd, SLI 670 at stock should be good enough to run most games at good settings.
Never mind Titan, the only time OC them is benching.
you can if you edit the bios/clocks:D
Yes it is! I run HD 7970 1200/1600 24/7,it'll go higher but I don't won't to burn my card.
Passive vram cooling on this crappy xspc razor water block.Can't wait to get my hands on Koolance AR797,then I'm going to tune up OC over 1250/1650.With those clocks I can see nice boost in fps over my stock 925/1325.
This is pretty spot on. I ran the Tomb Raider bench on the 120Hz, 1080P and it was nice and smooth but running it on the 1400P Dell was horrid. The screen was having a wobbly effect on the rocks and not very fluent at all.
I thought about doing that but would need to set the volts as well with using a custom BIOS and there is no way of doing that without using AB :(
