cant you edit the voltage?
last time I messed with bios was on a 5870,i think I could set the voltages not sure
I have my 3930K clocked at 4.625Ghz 24/7 and the beauty is, it is done in the BIOS, so no need to bother with loading up software to run the clocks. I don't like having programs loading in start-up, as I like to keep that as clean as possible. If we could do the same for a GPU, I would set and forget... Maybe one for the nVidia/AMD peoples to sort.
You can....sorta
MSI AB - Start with windows, Start minimized and Apply overclocking at system startup.
You dont notice the MSI startup, as it's instantly minimized![]()
That's cheating but not a bad shout![]()
Weve all become tree huggers man.After reading through this thread i thought the forum had changed its name, whats wrong with you people!!![]()
