Building a PC - Budget £1500-£1800
Asus boards are good, use them myself in a few of my builds. One thing to bear in mind is Gigabyte have a UK RMA address making life lots easier in the event of problems
Alright, the Gigabyte H87_HD3 board seems like a good shout. So, because connecting an Ethernet cable to the PC will be impractical, do you recommend using a network card (PCIE) or a USB wi-fi adapter?
Alright, I'm back again with an updated spec - getting closer to a final, great build now!
YOUR BASKET
1 x Asus SonicMaster MX299Q 29" Ultra Widescreen Ultra Slim Bezel LED Monitor - Black with Bang & Olufsen ICEpower Speakers £399.95
1 x Samsung 500GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE500BW) £289.99
1 x Patriot Intel Extreme Masters 32GB (4x8GB) DDR3 PC3-12800C9 1600MHz Quad Channel Kit (PVI332G160C9QK) £259.99
1 x Intel Core i7-4771 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £239.99
1 x BeQuiet Dark Power Pro P10 650W '80 Plus Gold' Modular Power Supply £139.99
1 x Corsair Obsidian 550D Quiet Midi Tower Case - Black (CC-9011015-WW) £119.99
1 x Microsoft Windows 7 Professional SP1 64-Bit - OEM (FQC-08289) £109.99
1 x Gigabyte H87-HD3 Intel H87 (Socket 1150) DDR3 ATX Motherboard £80.99
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £65.99
1 x Cherry G80-3000 Mechanical Keyboard - Blue Switch £64.99
1 x Asus HD 6450 SILENT EDITION 1024MB GDDR3 Low Profile PCI-Express Graphics Card £39.95
1 x Be Quiet! Shadow Rock Pro SR1 CPU Cooler £39.95
1 x OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £19.99
1 x TP-Link 300Mbps Wireless N USB Adapter (TL-WN821NC) £11.95
Total : £1,916.76 (includes shipping : £27.55).
I am still open to suggestions of course, and will continue looking at RAID options for the hard drives - but nothing too complicated, as my dad just wants a PC which will run fast, load programs quickly and will be reliable.
Also, I am not up to date on the lower end Graphics Cards but I assume that the HD6450 Silent I chose here will be enough to possibly run multiple monitors in the future.
You could save £50 on the PSU
YOUR BASKET
1 x Seasonic G series 650w '80 Plus Gold' Modular Power Supply £89.99
Total : £99.59 (includes shipping : £8.00).
Review: http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=348
Seems pretty good from that review, however I didn't really see much of a mention of noise - ideally, he'd like the computer to be as quiet as possible which is why I opted for that BeQuiet PSU. However, that Seasonic looks very good and if it is fairly quiet then I'll probably opt for that one instead.
I have a slightly new build idea for this system, it is X79 based - but I'm thinking it's probably a bit overkill for what he needs so I'll probably stick to a 4770 system. But here's the spec anyway:
YOUR BASKET
1 x Asus SonicMaster MX279H 27" Widescreen Ultra Slim Bezel LED Monitor - Black with Bang & Olufsen ICEpower Speakers £275.99
1 x Intel 4820K 3.70GHz (Ivybridge-E) Socket LGA2011 Processor - Retail (BX80633I74820K) £259.99
1 x GeIL EVO Leggera 32GB (4x8GB) DDR3 PC3-14900C10 1866MHz Quad Channel Kit (GEL332GB1866C10QC) £239.99
1 x Gigabyte X79-UD3 Intel X79 (Socket 2011) DDR3 Motherboard £154.99
1 x PNY Nvidia Quadro NVS 300 Dual DVI Low Profile Graphics Card - 512MB - GDDR3 SDRAM £109.99
1 x Western Digital Caviar Black 1TB SATA 6Gb/s 64MB Cache - OEM (WD1003FZEX) HDD £79.99
1 x NH-U12S Ultra-Quiet Slim CPU Cooler with NF-F12 Fan £52.99
Total : £1,880.53 (includes shipping : £22.20).
Here is roughly the same spec but Haswell based:
YOUR BASKET
1 x Intel Core i7-4770 3.40GHz (Haswell) Socket LGA1150 Processor - Retail £239.99
Total : £1,786.52 (includes shipping : £22.20).
Haswell takes dual channel ram, also here is a much better PSU but much cheaper, and a better mobo for the haswell build, incase you feel the need over clock in the future.
YOUR BASKET
1 x TeamGroup Vulcan RED 16GB (2x8GB) DDR3 PC3-17100C11 2133MHz Dual Channel Kit (TLD316G2133HC11ADC01) £129.95
1 x Gigabyte Z87-D3HP Intel Z87 (Socket 1150) DDR3 ATX Motherboard £107.99
1 x SuperFlower Golden Green HX 650W "80 Plus Gold" Power Supply - Black £73.99
Total : £321.53 (includes shipping : £8.00).
YOUR BASKET
This is for my dad's build by the way, and he won't be overclocking (I'll be getting the 4770, non k edition, for this). He will need 32GB of RAM so just 16GB of dual channel is not an option I'm afraid.
Also, I picked that PSU because this build needs to be quiet - is that Superflower quiet (I'd imagine it probably is given the quality of Superflower units)?
A xeon build is likely not necessary for the work he will be doing, an Haswell i7 4771 will be the better option in my opinion. Not a lot of storage will be required either, as his current computer has only ~250GB used; so the 500GB EVO SSD and a 1TB HDD (for backups) are enough.
That GTX-650 could be a bit loud for this build couldn't it, that's why I opted for the low profile quadro series GPU in my spec.
Also, is there any reason why you chose 2 kits of dual channel as opposed to 1 kit of quad?
Cheers for the advice and suggestions everyone, by the way :)
The ram was meant to be 2x 16gb my bad, i picked dual channel since 1150 only supports 2 channel ram I believe, only x79 I believe offers 4 channel ram, so just get 2x 16gb. From what I have seen/heard the Superflower is really quiet and with the amount you save it is well worth it.
Ok, cheers that's very helpful; didn't realise Haswell doesn't support Quad Channel RAM. :)
Probably because it is cheaper buying 2 kits of dual channel as opposed to 1 kit of quad channel.
YOUR BASKET
1 x TeamGroup Xtreem LV 16GB (4x4GB) DDR3 PC3-20800C10 2600MHz Dual/Quad Channel Kit £239.99
1 x GeIL EVO Corsa 32GB (4x8GB) DDR3 PC3-12800C10 1600MHz Quad Channel Kit (GOC332GB1600C10QC) £229.99
Total : £719.57 (includes shipping : £8.00).
