You could save £50 on the PSU
YOUR BASKET
1 x Seasonic G series 650w '80 Plus Gold' Modular Power Supply £89.99
Total : £99.59 (includes shipping : £8.00).
Review: http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=348
Haswell takes dual channel ram, also here is a much better PSU but much cheaper, and a better mobo for the haswell build, incase you feel the need over clock in the future.
YOUR BASKET
1 x TeamGroup Vulcan RED 16GB (2x8GB) DDR3 PC3-17100C11 2133MHz Dual Channel Kit (TLD316G2133HC11ADC01) £129.95
1 x Gigabyte Z87-D3HP Intel Z87 (Socket 1150) DDR3 ATX Motherboard £107.99
1 x SuperFlower Golden Green HX 650W "80 Plus Gold" Power Supply - Black £73.99
Total : £321.53 (includes shipping : £8.00).
This is for my dad's build by the way, and he won't be overclocking (I'll be getting the 4770, non k edition, for this). He will need 32GB of RAM so just 16GB of dual channel is not an option I'm afraid.
Also, I picked that PSU because this build needs to be quiet - is that Superflower quiet (I'd imagine it probably is given the quality of Superflower units)?
The ram was meant to be 2x 16gb my bad, i picked dual channel since 1150 only supports 2 channel ram I believe, only x79 I believe offers 4 channel ram, so just get 2x 16gb. From what I have seen/heard the Superflower is really quiet and with the amount you save it is well worth it.
Also, is there any reason why you chose 2 kits of dual channel as opposed to 1 kit of quad?
Cheers for the advice and suggestions everyone, by the way![]()
Probably because it is cheaper buying 2 kits of dual channel as opposed to 1 kit of quad channel.
