is it the 290x or just the 290? cause the r9 290 does NOT have a True Audio chip.
R9-290 does have Trueaudio. It's built into all the Hawaii chips.
I do but i have a small spot fan there so it wouldn't fit. Without that spot fan gpu1 runs 1-2c warmer than gpu2 and in my world that is unacceptable.
Your onboard will most likely be fine until you start investing in Audiophile graded headphones, at which point you should be buying an external DAC that takes digital or coax out and use that with your headphones.
Surround can be done(and should be done when it comes to headphones) virtually. Dont bother with True surround sound headsets. The drivers are a lot smaller and the cost a lot higher and you wont get the sound you are paying for. This is the point with AstoundSound(which can use the True Audio chip) that it does such a good job emulating surround sound on stereo headphones. Also there are alternatives for games that dont have support for this, such as Razer surround application which is free. I have no idea how good or bad it may be but it is still free.
Poll: Mantle release with 13.55 drivers-> Next week or last week?
All I want is something that makes my 2 x HD5870's perform in Crossfire with BF4 because so far NOTHING has achieved that, which annoys me as out of Crossfire I can play the game OK, but with settings down of course. If this fixes great, if not time to go Nvidia again and keep your eyes open in the MM.
What cpu have you got?
i930
Follow this guide. Once you've disabled ULPS, setup gpu overlays and can monitor gpu usage we can diagnose the problem better. I assume you're using the latest 13.12 WHQL drivers? If not, upgrade. Do all that, then run the game and report gpu usage to me. Should be at 90%+ for both gpu's while playing.
I am running 13.12 WHQL's.
The rest is science, give me a clue![]()
How much though? I don't fancy spending a lot for a small change. After all i can get stereo through my current headset if i turn the surround option off.
No Tueaudio for hd 7xxx??R9-290 does have Trueaudio. It's built into all the Hawaii chips.
Dont bother with that mate, get yourself an External DAC running out of your onboard digital out and your golden. Much better than any sound card you can buy.
