Currently running a GTX680 with two displays, a 27" 2560x1440 and a 24" 1920x1080, and it keeps crashing and knocking my 27" out to zero input. Anyone else had this at all?
Did you tick the fresh install option under the custom installation?
What does the error message say?
Try swapping over the inputs for the screens on the card end, see if it then happens to your 24". Hit the print screen button as soon as it happens or as soon as you see the error message. You should then be able to paste it into Paint or Photoshop after you hit ok to get the screens picture back.
It will probably be saying "The display driver has stopped responding" and this is generally a sign of a faulty card. Do a complete clean install of drivers, make sure you don't have a virus like that bitcoin virus and use Display driver uninstaller to clear all the old drivers out.
http://www.guru3d.com/files_details/display_driver_uninstaller_download.html
If you still have problems, then sure seems like the card is faulty.
I've got an RMA set up already, so can use it if necessary. Of course if it's something else, I'd prefer to hold on to it. That's very helpful though, thank you.
It could cost you if there is no fault found, so best to make sure before sending it off.
Just got a crash with the older driver. Blacked out for 10 seconds and then came back to this.
Yep, not a good sign.
Make sure your GPU is idle on desktop (run Afterburner or precisionX) - If all clear there, run DDU and clean out all the nVidia drivers and reinstall the latest - If still doing it, RMA![]()
The card is a KFA2, does it matter that PrecisionX is EVGA? And I've run the DDU etc already, I'm now back to one screen![]()
Probably good to run on one screen whilst trouble shooting.
PX is good for all nVidia cards, so run that.
http://www.guru3d.com/files_tags/precisionx.html
If still no luck, you know the score.
All looks good there. Hot for idle clocks or have you just been testing it?
Haven't touched a thing.. Looks like it's going back![]()
