- 13 Apr 2013
- La France
Save up for a newer car instead?
All in good time. Now is not the time. Thanks for the advice?Save up for a newer car instead?
Guys, he drives a 2002 Polo. He's not looking for race spec suspension, he's looking for a lack of "get your head under the arch gap" solution. You may buy stuff... sure, but do they work? Sure, the JOM ones will work. Will the drop the car? Yes. Will they be TUV approved? Yes.
Will the ride suffer? Yes. Will they last a lifetime? No.
the OP has a £200+ processor in his signature. why would you consider spending less than this on a product that is integral to your personal safety?
on ebay there are a set of 9N Koni FSD dampers with eibach springs, id consider those
Can you stick a link up? Bearing in mind the car is worth £1500 and I'm not made of money?![]()
Don't modify the car then, if you don't have the money to do it properly, then don't do it at all.
I've have Eibach springs on 2 Ford Focus' that I've owned, both have been on existing dampers. Through 6 years of ownership I've never had a problem.
50mm is too big a drop for standard shocks, 30mm drop on Eibach springs will do nicely.
Thanks for all the feedback. I knew £80 lowering springs were too good to be true
I do still want a 50mm drop but it seems like I'm going to have to fork out a bucket load of money or compromise.
There are also £175 suspension kits on the bay, guessing they're crap too?
Also type Rs are already quite low whereas 9N's ride really quite high, I think 50mm suits them well.
and as for coilovers, as far as i can tell you have to spend almost a grand to get something good
