You went to football instead of spending time in the gym?
Short of leaving your workout because you have house cleaning to do, that's pretty lame!![]()
I know
It wasn't even REAL football... and we lost!
I'll make up for it today, boss!
I know nothing about this but what about some more explosive exercises like power cleans?
And doesn't the NFL combine give you some good ideas of what they judge worthy - 225lb bench and 40 yd dash being two that spring to mind. I also found some training logs of current NFL players somewhere, worth a google.
Whilst powercleans (and snatches) are a crucial part of explosive power training, they are pointless if done wrong. And unless a coach can make sure you are doing them correctly, you will do them wrong.![]()
Whilst I didn't play NFL, I played rugby and most of our training was based around compounds and explosiveness. I was 100kg ish at just under 6'1". Now I am around 92kg at around 13.5% bf.
Must do exercises:
Deadlifts
Squats
RDLs
Walking lunges / reverse lunges
Power cleans
Push press
Shoulder press
Box jumps
Bench
Dips
Rows (of all kinds)
Pull ups
and all variations of the above. Do all those and you'll seldom need to train arms independently - your arms form such a minor part of your power when running, tackling whereas your legs are what generate your power in throwing, moving, pushing and pulling. Things like pull ups, rows, pressing and so on will make your arms grown through the fact they are used incidentally when training those movements.
Worry less about isolation - by doing the walking lunges, split squats, and so on you'll build up that independent balance in your legs. Power comes from compound movements, not arm curls or machines - free weights for 80% of your training, 20% machines/isolation. You either want to be functional and effective, or look pretty - one will give you both, one will give you just one, I'll let you think about which one you need
Then a LOT of rotator cuff and mobility work - especially on the knees, hips, and again shoulders. See the mobility thread started by Icecold.
Isolation: single joint exercise (i.e. isolating a single muscle or group of muscles)...
Compound: multiple joints, multiple muscle groups. Just... better.![]()
I understand the need for tackling with the arms more, but strong arms come from strong back, chest, core and legsA boxer/wrestler uses their legs for developing power, not just a bicep
Yes small steps, and doing that mobility work will help your knees, as well as the individual movements suggested. Best to start slow and learn carefully than rush in and injure yourself.
the 225lb bench looks horrific- In years gone by i've watched combines of all the fresh college crop get so many reps on it, I doubt I could get 1 rep atm
- It all depends on position but I think the average is in the 30's... with awesome being 40+
I think its like 100KG right? ... I don't really work in lbs
Oh, what is even worse too, is if you do a bad rep. they don't count it!
Yarp, it close enough to 100kg. Worryingly the record is something like 49 reps @ 225lbs![]()
Weightlifters don't bench. I think you mean 'powerlifters'...![]()
