Yeah. I think you've made the right decision
The FX series doesn't have 8 real cores for starters - the 1100T has 6 real cores. The OP is running at 4.2ghz on his 1100T also, which is a pretty damn good OC and reduces the gap further.
The difference between piledriver and phenom II is less in the favour of phenom II than bulldozer and phenom II was but it's still there in the favour of phenom II for gaming. As such the OP would be spending a lot of money on an upgrade that provides very very little benefit.
The 1100T has 6 integer units, 6 decoders, 6x L1 and 6x L2
The FX-83## has 8 integer units, 4 decoders, 8x L1, and 4x L2
It has 8 real cores, the only real difference is 2 cores share one decoder and L2.
As for clock speeds, there is about as much chance of running a 1100T @ 4.2Ghz as there is an FX-83## at 4.8Ghz or even 5Ghz
I'm not suggesting T C should replace his 1100T with an FX-83##, what i'm responding to is comments like this
Don't bother upgrading to an FX8350 either. Assuming you manage to overclock it incredibly well and hit something near to 5ghz you'll gain pretty much nothing in anything gaming-related. If your overclock is bad and you end up with a similar clock speed to now you'll probably lose performance.
No disrespect but that is a completely inaccurate statement.
Look again at Tonester0011 example...
That is a very clear performance advantage, some 28%, even the 3.5Ghz FX-6300 beats the 3.3Ghz 1100T by some 15% (6 Cores vs 6 Cores 3.5Ghz vs 3.3Ghz) in other words you would have to run the 1100T at a round 4Ghz (maximum Average overclock) to match the stock 3.5Ghz FX-6300, never mind the FX-83##
You may well say the FX-6300 only has 3 real cores, be that as it may, though its not, those 3 cores would be more than twice as fast as the Phenom II cores, no, just no.
PS: having said all that a lot of people in this room recommended they upgrade their Sandy Bridge with an Ivy Bridge for no performance gain at all.
