Just noticed this thread for the first time, awesome.
Are there any modestly priced kits you can buy to start off with, I don't fancy spending close to £1000 and then crashing it.![]()
Can anyone point me towards the parts required to make one of these (an FAQ even) and how much it would cost (don't want /need fanciest!)
Whatever length DaVid recommends on his website on rcexplorer. i think its 48cm.
yes slight wobble when hovering.
i think its down to balancing which is way... going ti have to read up on balancing a tri properly, moving the battery wont cut it i dont think.
ill do some reading on tuning the kk board too... p gains is it or something. cant remember atm.
Have a look at my posts, ive just built one.
also have a look at http://oddcopter.com/2012/12/12/easy-diy-quadcopter-build-part-1-the-parts-list/
99.9% of my parts were from hobbyking
Yeah, my last one was 45cm, simply because I bought 90cm booms from B&QThinking of trying shorter front arms this time for more agility, with a slightly longer tail.
Oh, and are you using counter rotating front props? Never used to but the props were in stock this time so thought I'd give it a go
Phantom and camera firmware updated, the transmitter didnt need one. I changed the signal to FCC with the app so I didnt bother with the screw. Just charging all the batteries now for first flight which might be tomorrow now.
