My SLK LPG Converted
11 Apr 2010
This car is just for me, my castle and I am the king, no child, no wife =). I really don't need the space on the boot. On the other hand i can justify the cost of having a second car and i try to keep the cost down. I do love the car to bits but on petrol is expensive to run.
For a second car you must do a lot of miles to justify the conversion, especially in something like an SLK200?
It's an slk200......it's hardly going to be other worldly poor on fuel.
Still a bit confusing in terms of the financial goals if you're happy enough to have another car to use tbh but each to their own!
I do 20k+ per year.
As per a second car some time is a must for me. Again could be a cheap car to run not a slk. But all in on so far so good.
Hi
This is my SLK 200 which I converted to LPG.
Me personal I din't notice any loss of power what so ever on LPG.
I did change the spark plugs to NGK LPG7.
I had a smart roadster which use to do a mile with 0.14p and now with the LPG my SLK cost me 0.14p per mile.
I lost the space from the trunk but i ca not be bother.
http://imgur.com/QoyH3jZ
http://imgur.com/VLUTwq6
http://imgur.com/8KaFOF2
http://imgur.com/UtWMAYk
http://imgur.com/UN38VUz
14p/mile? That's not great. On my fill-up this eve I spent just under 9.5p/mile, and that was a 2.8L petrol.. :confused:
Looks like a Zavoli Zeta reducer to me /lpg nerd.
Very cheap for a fitted system - I have procured all the parts to fit mine albeit for a 250hp 4 cylinder + toroidal tank and that alone came to over £650.
Are there any other costs involved? Does it alter your vehicles tax band? What is insurance like?
-Yearly filters change (££cheap, 10mins)
-Yearly remap/'tune up' is a good idea, 1hr of LPG fitters time or DIY with USB>RS232 cable depending on system.
Depending on age of car you can get a small tax reduction ~£10/year if registered with DVLA as dual fuel.
Insurance either don't care, or classify it as modification and load premium a smallamount in accordance. Some insist on LPGA install certificate, most don't.
One of payment of 870. Then my insurance charge me 25 for adding Lpg on my insurance. No chance in tax band. I will benefit of 15,pounds reduction on my tax band.
Prior to the slk I had a smart roadster 0.7l and with that I use to do a mile with 0.13p so I'm not sure how you mange that consumption with a 2.8l engine...
Indeed that does look odd - 30mpg sees me spend about £0.21 / mile at the moment (I'm guessing by 0.13p you actually mean 13p?) so i'd need to be achieving 60mpg from my 3 litre 6 to even get close to 9.5p/mile
