Since SteamOS was first released in December 2013, Valve has been quick to squash bugs and add much-needed functionality. It still isn’t clear when Valve will launch the final version of SteamOS (hopefully later this year), but it took a big step forward recently by releasing an ISO version that includes an easy-to-use Windowsinstaller and dual-boot functionality. SteamOS itself is still pretty much just a customized Debian distro with Steam pre-installed.
A couple of weeks ago, back when Valve unveiled its Steam Machine hardware partners at CES 2014, SteamOS also gained support for AMD and Intel GPUs. Previously, only Nvidia graphics cards had been supported. The AMD Catalyst driver implementation is fairly preliminary at this point, with slow-than-Windows performance and some visual glitching, but it should improve over time (as long as SteamOS actually goes on to be a critical success).
The SteamOS installer looks a lot like the Debian installer
The SteamOS installer looks a lot like the Debian installer… because it is
The new ISO version of SteamOS includes a Windows installer (the standard Debian installer for Windows), official support for dual-booting, support for legacy BIOS (non-EFI) systems — and if you burn the ISO to disc, it obviously supports installation from DVD. (You can happily mount the ISO in Windows and install from there, too.) Valve says that dual-boot support has received “very little testing,” so you shouldn’t yet try it out on your main computer — unless you’re prepared to lose everything. (Read: What is EFI, the long-overdue replacement for BIOS?)
Curiously, most of the changes in this most recent build of SteamOS were borrowed from Ye Olde SteamOSe — a modified version of the SteamOS installer that was released very soon after Valve first published its code, and has been developed side-by-side since. There are still lots of features in YOS that the official SteamOS lacks, though, such as real support (including 3D acceleration) for VMware and VirtualBox. (And indeed, YOS is a much simpler way of virtualizing SteamOS than our original guide, which was really rather convoluted.)
The SteamOS desktop, in VirtualBox
Moving forward, there isn’t a whole lot of transparency on Valve’s plans for SteamOS. It looks like the company is just going to slowly trudge forward until everything is polished, with sporadic releases when something major occurs. SteamOS’s major features, such as in-home streaming of PC games to your living room Steam Machine, or better-than-Windows performance, are still nowhere to be seen. The incompleteness of SteamOS, combined with the recent change to the Steam Machine controller, suggest that we won’t see the final build of SteamOS (or the Steam Machines) until mid-2014 at the earliest.
