Ideal Temperature for my Processor?
25 Jan 2014
Hey Guys,
I would really appreciate your help! I'm an amateur when it comes to building computers: I built mine a few years ago and my heatsink and fan were horrendously loud so today I brought myself a Cooler Master Hyper 212 Evo and spent the last 3 hours installing it. I spent the majority of my time trying to sort out the thermal paste and I'm paranoid I've done it wrong...
I was wondering what sort of temperature should I expect it to all to be? My processor is a AMD Phenom ii X6 - I've downloaded SpeedFan and it says my "Core" temperature is currently 25 degrees C which sounds brilliant but I just wanted to check that is right?
Here's a link to a screenshot of my Speedfan results. :)
Cheers guys!
That.. seems extremely low.
What's the ambient temperature in your room like 15 degrees lol?
Download http://www.techpowerup.com/realtemp/ - The readings on speedfan aren't exactly clear, after downloading it, it might be worthwhile running a benchmark to see your max temperatures, Intel burn test for instance will give you the HIGHEST and worst possible temperatures you might experience.
Ah...
I tried RealTemp but it says my processor isn't supported... Any other programs I can try?
Playing a bit of Counter Strike: GO (my last heatsink used to go crazy in that game), it says my Core is now 30C. :-\ GPU seems to go up to around 50/60 though?
Ah...
Besides, the temperatures you're experiencing are really good.
I was sceptical because with a core temp of 26 degrees seems very unlikely in the average 21-23 degree room without some kind of active cooling, water or refrigeration
Nope, normal English bedroom! Strange. I ran the IntelBurnTest program you suggested with "10 runs" and the results were consistent - All ten said 3.257006e-002 as their result so I guess all is ok!
Just tried this HWMonitor program and all cores are around 26 degrees C so I'm gonna say I did a good job!!! :D
Cheers for all your help guys!
