Well tried everything to beat my Arch Enemy's Score --> setter 3770k:4.5GHz SLI 670:1267/1753>Score=1850, with 4820k:4.6GHz SLI 670:1240/1745>Score=1849 could not squeeze anymore out of my 670's.
Even though my CPU was at 4.6 to setters 4.5 it was GPU Speed was the deciding factor, humbug 1 point in it - Score=1850 / Score=1849, good one bud enjoyed trying to beat it with my CPU at 4.6 which is for my PC 24/7 setting.
Result Score 1849 at 4820k:4.6GHz SLI 670:1240/1745
Err, no, l take it that it helps? l,m a silly oldphart.And on the scoreboard.
Have you tried turning hyperthreading off.
Hi, not interested in being on the scoreboard so here's my new r9 290 Msi gaming score:
cpu and gpu at stock.
core: 977
Mem: 1250
FPS: 51.4
Score: 1294
Min: 23.8
Max: 105.3
Vrm 1: 72c
Vrm 2: 60c
Max Temp: 73c
Idle Temp: 29c
Max Fan: 49% (quiet)
Hope this info helps someone out.
Ps: the above screenshot was done on the exact same settings using Win 8.1 as you can see some slight differences from the above figures which were in Win 7.![]()
Will give it ago Kaaps,
Oldphart.![]()
Does not help at all Kaaps, l think its the GPU's are at their limit.
Will leave it for know and have a tinker another time.
Thanks anyway Kaaps.![]()
Disabling hyperthreading only gives a few extra points on a good day and it was worth a shot as I think you were only looking for another 2.![]()
I got 6 extra points from disabling Hyper Threading.![]()
