- 17 Jul 2009
If you want to venture into 3d why didn't you go with a 6ch model from the outset? I've never seen a heli forum recommend anything less than a 6ch to start with.
My first heli was a trex550.....with a dx7s radio. Maybe a little big looking back but I would probably go with a blade130x if I were to do it again. Flies like a bigger heli and crash costs are pennies at most.
i must have been reading the wrong forums >.< but i dont mind later on buying something that does 3d my 1st thought was to get a Walkera HM Genius CP V2 as my 1st heli....
Had my honeybee v2 for a few years now, crashed it lots but its easy to repair and lots of spares available. If its your first time then id suggest getting the training gear and putting that on makes the helicopter easier to lift off and land and stops it from crashing to earth with a massive bang, will save you numerous new blades.
Another tip is if your flying it outdoors (which i only do) make sure its a calm day as the bee doesnt like wind, it will get thrown about all over the place.
Its worth looking at some of the youtube videos, these will tell you how to setup the bee and repair it, get a few extra lipo batteries too and a better charger, the one that comes with the bee aint that good.
If you cant afford phoenix sim than another good one that works well with the honeybee's controller is clearview rc. You can crash as many times as you want![]()
https://www.buzzflyer.co.uk/RC-Helicopters/ESky-Honey-Bee-V2-2.4G/p-70-124/
this is what i got + the Deluxe Deal comes with the training gear plus some extra's says i can get 20mins flight time which is great since i only managed like 5mins on my 3ch.
With the sim will the transmitter work that comes with the honey bee? also i don't know if any of these extra comes with the cable required if it did..
The heli will arrive tomorrow.
