games are blurry @ 2560 x 1440.
1 Dec 2011
SW3
With my 780, playing a quick round of COD4, everything maxed out i notice that when running through the game, it becomes quite blurry, my drivers are up to date.
Does anyone have the same issue with 2560 x 1440?
Any overdrive setting on the monitor thats available to you? The pixel response might be slow enough for you to notice ghosting.
There's is no menu on the monitor to go into, it maybe something in the NVidia control panel?
I'm using DL-DVI, should it say in CP im using DL?
Have you tried the in game video setting? I get it a lot with slightly older games (GTA IV as an example) my native is 1080p but it loves to default down to 800x600 for some reason.
Ye I have every setting maxed out in game, went through the resolutions in game last night and have the same issue with all of them.
If it is blurring when displaying movement, it looks like you will need to RMA it then and order something from Overclockers. Yamakasi is one of the brands explicitly mentioned in the sticky post.
Im not expert but it sounds like motion blur or Input lag.
Some games have motion blur in which can be turned off most of the time.
If its input lag causing ghosting its due to the monitor. Bottom line is that not all monitors are created equal and that some panels have very high lag which causes ghosting and blurring of imagines as it cant keep up with what is happening on screen. IPS monitors do tend to have higher lag over TN panels hence why the new ROG 1440p monitor coming out is a TN panel as to get the good input rates IPS just cant do it at the minute.
Just my thoughts
