Windows 8.1 for benching. Come on man!!! 7 64 bit for 11. Default driver run!!! changing quality etc has adverse effect. Most efficient and RAM timings effect Physics score nicely!!!
CT is often PSU actually , only test all cards and CPU working full tilt. I doubt this in your case with Seasonic. Use ROG connect to clock down your CPU for CT to make sure you pass or have a profile on AB and clock down your cards a touch. CT is only 10% of overall score anyway.
i'll test at cl10 at same gpu clocks and see if it makes a difference.
