Star Swarm - Oxide bench thread
Caporegime
24 Sep 2008
Essex innit!
Ok guys, post your bench results here for the Star Swarm - Oxide benchmark.
Rules.
1. List your GPU and CPU and what the clock speeds are.
2. Add "Official entry" to the top/title of your post.
3. Users can alter the deferred contexts number to 1 (from 0) if you wish (steam/steammaps/common/star swarm benchmark/assets/settings_Extreme.ini
4. Click Follow and click Extreme and then choose either "Start Mantle" or "Start D3D" (as shown in the spoiler)
5. Copy and paste you complete results with the rest of the info.
Link to how your entry should look like.
http://forums.overclockers.co.uk/showpost.php?p=25813564&postcount=260
Any questions, fire away and enjoy :)
Top 25 DX results
  1. 109.09 - Andybird - 4930K @ 4.5 - Titan @ 1140
  2. 84.14 - Ian Evey - 3570K @ 4.8 - 780 @ 1215
  3. 81.93 - Gregster - 3930K @ 4.625 - Titan @ 1015
  4. 76.70 - Spankingtexan - 4770K @ 4.5 - 780 @ 1150
  5. 66.23 - los - 4670K @ 4.5 - 970 @ 1427
  6. 60.78 - Coupe69 - 3820 @ 4.2 - 680 @ 1202
  7. 56.79 - SkeeterUK - 3570K @ 4.5 - 670 @ 1150
  8. 41.65 - Humbug - 1090T @ 3.2 - 7870 @ 1150
Top 25 Mantle results
  1. 84.43 - Geeman1979 - 3930K @ 4.5 290X @ 1300
  2. 82.26 - Humbug - FX9590 @ 4.7 - 290 @ 1100
  3. 73.27 - theRealDeal - I7-920 @ 4.0 290 @ 1100
  4. 64.66 - Humbug - 1090T @ 4.2 - 290 @ 1171
  5. 57.19 - Humbug - 1090T @ 3.2 - 7870 @ 1150
  6. 55.02 - Fs123 - 3770K @ 4.2 - 7950 @ 1200
  7. 53.75 - Thebennyboy - FX8320 @ 4.2 - 280X @ 1200
My best so far
Oxide Games
Star Swarm Benchmark - ©2013
C:\Users\Uksoldierboy\Documents\Star Swarm\Benchmark_14_01_30_1849.txt
Version 0.95
01/30/2014 18:49
== Hardware Configuration =================================
GPU: AMD Radeon R9 200 Series
CPU: GenuineIntel
Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
Physical Cores: 4
Logical Cores: 8
Physical Memory: 8524558336
Allocatable Memory: 140737488224256
== Configuration ==========================================
API: DirectX
Scenario: ScenarioAttract.csv
User Input: Disabled
Resolution: 1920x1080
Fullscreen: True
GameCore Update: 16.6 ms
Bloom Quality: High
PointLight Quality: High
ToneCurve Quality: High
Glare Overdraw: 16
Shading Samples: 64
Shade Quality: Mid
Motion Blur Frame Time: 16
Motion Blur InterFrame Time: 2
Detailed Frame Info: Off
== Results ================================================
Test Duration: 120 Seconds
Total Frames: 4601
Average FPS: 38.34
Average Unit Count: 3556
Maximum Unit Count: 5332
Average Batches/MS: 984.53
Maximum Batches/MS: 1784.68
Average Batch Count: 27751
Maximum Batch Count: 134165
Seems inconsistent but good fun seeing all those units on screen
4770K @4.6
Asus 290X @1150/1400
Just gave it a run on my 7950 @ 1100/1250
Oxide Games
C:\Users\Kyle\Documents\Star Swarm\Benchmark_14_01_30_1902.txt
Version 0.95
01/30/2014 19:02
GPU: AMD Radeon HD 7900 Series
CPU: GenuineIntel
Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz
Physical Cores: 4
Logical Cores: 4
Physical Memory: 4252483584
Allocatable Memory: 8796092891136
API: DirectX
Fullscreen: True
Bloom Quality: High
Glare Overdraw: 16
Shading Samples: 64
Shade Quality: Mid
Total Frames: 2595
Average FPS: 21.62
Average Unit Count: 3828
Maximum Unit Count: 5513
Average Batches/MS: 728.11
Maximum Batches/MS: 1050.76
Average Batch Count: 38040
Maximum Batch Count: 205357
Oxide Games
C:\Users\Greg\Documents\Star Swarm\Benchmark_14_01_30_1909.txt
Version 0.95
01/30/2014 19:09
GPU: NVIDIA GeForce GTX TITAN
CPU: GenuineIntel
Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz
Physical Cores: 6
Logical Cores: 12
Physical Memory: 17122181120
API: DirectX
Fullscreen: True
Bloom Quality: High
Glare Overdraw: 16
Shading Samples: 64
Shade Quality: Mid
Total Frames: 7117
Average FPS: 59.30
Average Unit Count: 3905
Maximum Unit Count: 5393
Average Batches/MS: 794.71
Maximum Batches/MS: 2151.02
Average Batch Count: 15495
Maximum Batch Count: 185700
That is with a single Titan and a 3930K @ 4.625Ghz
@ Recce, I will add settings to the OP cheers :)
Here's mine. 7950 @ 970/1275Mhz
Oxide Games
C:\Users\Family\Documents\Star Swarm\Benchmark_14_01_30_1911.txt
Version 0.95
01/30/2014 19:11
CPU: GenuineIntel
Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
Physical Cores: 4
Logical Cores: 4
Physical Memory: 8550182912
API: DirectX
Fullscreen: True
Bloom Quality: High
Glare Overdraw: 16
Shading Samples: 64
Shade Quality: Mid
Total Frames: 3594
Average FPS: 29.95
Average Unit Count: 3655
Maximum Unit Count: 5486
Average Batches/MS: 887.69
Maximum Batches/MS: 1222.27
Average Batch Count: 31175
Maximum Batch Count: 102044
First Run
PC is completely stock 4770k and stock 290
Oxide Games
C:\Users\Si\Documents\Star Swarm\Benchmark_14_01_30_1849.txt
Version 0.95
01/30/2014 18:49
CPU: GenuineIntel
Physical Cores: 4
Logical Cores: 8
Physical Memory: 8474673152
API: DirectX
Fullscreen: True
Bloom Quality: High
Glare Overdraw: 16
Shading Samples: 64
Shade Quality: Mid
Total Frames: 3472
Average FPS: 28.93
Average Unit Count: 3814
Maximum Unit Count: 5236
Average Batches/MS: 749.80
Maximum Batches/MS: 1263.29
Average Batch Count: 31107
Maximum Batch Count: 203831
2ND RUN
4770k @ 4.5ghz - 290 STOCK
Extreme / Attract
Oxide Games
C:\Users\Si\Documents\Star Swarm\Benchmark_14_01_30_1911.txt
Version 0.95
01/30/2014 19:11
CPU: GenuineIntel
Physical Cores: 4
Logical Cores: 8
Physical Memory: 8470953984
API: DirectX
Fullscreen: True
Bloom Quality: High
Glare Overdraw: 16
Shading Samples: 64
Shade Quality: Mid
Total Frames: 3611
Average FPS: 30.09
Average Unit Count: 3643
Maximum Unit Count: 5310
Average Batches/MS: 919.25
Maximum Batches/MS: 1571.59
Average Batch Count: 34801
Maximum Batch Count: 123447
3rd RUN
4770k @ 4.5ghz - 290P @ 1110/1250
Oxide Games
C:\Users\Si\Documents\Star Swarm\Benchmark_14_01_30_1933.txt
Version 0.95
01/30/2014 19:33
CPU: GenuineIntel
Physical Cores: 4
Logical Cores: 8
API: DirectX
Fullscreen: True
Bloom Quality: High
Glare Overdraw: 16
Shading Samples: 64
Shade Quality: Mid
Total Frames: 5303
Average FPS: 44.19
Average Unit Count: 3803
Maximum Unit Count: 5335
Average Batches/MS: 835.47
Maximum Batches/MS: 1499.87
Average Batch Count: 22511
Maximum Batch Count: 75735
I will sort out some sort of Amntle vS DX results tomorrow but for now, add away :)
Settings to be used:
Feel free to run in both Mantle and D3D as well :)
Cool Greg, This will be interesting to see what cards run at before and after :cool:
Doubt either side has multi gpu support for this yet, i know AMD does not. They say its coming in a future driver. So single cards only, for now. Unless you create your own profile i guess.
Not sure if we're picking the best/most consistent bench option either. Guess we'll discover that in time. Be interesting to see what i get in Mantle vs this score.
[email protected]
290 Single card at 1230/1625
13.12 WHQL
Oxide Games
C:\Users\Matt\Documents\Star Swarm\Benchmark_14_01_30_1918.txt
Version 0.95
01/30/2014 19:18
CPU: GenuineIntel
Intel(R) Core(TM) i7-2700K CPU @ 3.50GHz
Physical Cores: 4
Logical Cores: 8
Physical Memory: 17145409536
API: DirectX
Fullscreen: True
Bloom Quality: High
Glare Overdraw: 16
Shading Samples: 64
Shade Quality: Mid
Total Frames: 5834
Average FPS: 48.62
Average Unit Count: 3913
Maximum Unit Count: 5508
Average Batches/MS: 823.25
Maximum Batches/MS: 1688.75
Average Batch Count: 21804
Maximum Batch Count: 212179
My run some parts was low 6fps slideshow. :eek:
Oxide Games
C:\Users\Frankie\Documents\Star Swarm\Benchmark_14_01_30_1914.txt
Version 0.95
01/30/2014 19:14
CPU: GenuineIntel
Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
Physical Cores: 4
Logical Cores: 8
Physical Memory: 17137754112
API: DirectX
Fullscreen: True
Bloom Quality: High
Glare Overdraw: 16
Shading Samples: 64
Shade Quality: Mid
Total Frames: 3120
Average FPS: 25.98
Average Unit Count: 3788
Maximum Unit Count: 5473
Average Batches/MS: 676.59
Maximum Batches/MS: 865.13
Average Batch Count: 26507
Maximum Batch Count: 153908
Oxide Games
Version 0.95
01/30/2014 19:14
CPU: GenuineIntel
Physical Cores: 4
Logical Cores: 8
API: DirectX
Fullscreen: True
Bloom Quality: High
Glare Overdraw: 16
Shading Samples: 64
Shade Quality: Mid
Total Frames: 3120
Average FPS: 25.98
I had it down to 8 fps in one spot that I noticed. Flys and slows and flys and slows :D
I am very interested to see how you Mantle users get on compared to what you are posting :)
