Thanks mate,
do you mean these?
http://www.overclockers.co.uk/showproduct.php?prodid=MY-121-KS&groupid=701&catid=8&subcat=2426
Kingston KVR1333D3E9SK2/16G 16GB 1333MHz CL9 DDR3 ValueRAM ECC Memory Kit
Thanks mate,
do you mean these?
Ive also dropped a Blackgold BGT3600 TV card in it, that can do dual HD SAT & dual freeview HD too, price but works very well.
@Kefen
Yes it's worth it if you want silence
I use a 90W Pico cost me roughly £25, but the power brick cost another £30 I think can't exactly remember, I maybe should have gone a little higher wattage but the brick is 120W. Runs 4 2tb Adaptec Scsi 1 80GB SSD and 1 TB Drive.
All runs OK with this wattage although only niggle you need a lot of extra molex cables to connect the 1 connection you have to get all drives powered up.
You get these items from Ebay and mini itx if you Google.
It is also worth changing the back fan to a scythe controlled one or other if you want near silent operation, just adjust speed to around 600rpm or it won't boot.
Added my LCD back into my N54L
.Where did you get your LCD?![]()
Are HP still actually building the G7 Microserver, or are they still just running down existing stock? As good as the G7 has been, I'd still like to see the back of it. Once it disappears there might be some better deals on the much nicer G8.
Does anyone know why the price has gone up again? I was thinking of getting one of these after my recent pay day and all 3 sites I know that stock them are now listing at around £250 before cash back...![]()
For what I use the G8 is a better option than the G7 but what can you do, once I get a decent deal come through I'll swap from the old to the new, Plex has meant I need more CPU grunt lol...
