I've been faffing about with the KFL quietly bemoaning my unwise and frankly n00bish choice of 34GA Kanthal. I have made about 8 coils so far and just cant get enough wraps to even get a half respectable wick cover and silly high ohmage - just 2-3 wraps were coming out at 2.5-3.5 ohms or there abouts. Sure they vaped ok, but just not quite where I would have liked.
I even tried to build a micro-coil and that came in at 6 ohms!
Then I saw a youtube on twisted wire and thought ah-ha! Twist the wire halve the resistance or something - so I got my drill out and tried and tried to twist the wires with an allen key in the chuck - kanthal kept breaking. Got fed up and just attached the wire directly into the chuck and whooom... one twisted wire.
After 3 more failed builds using the twisted wire (running out of Kanthal now) I have managed to fluke a 1.5 ohm coil with 5.5 wraps and its running at 3.1 volts - sweet mary mother of god it kicks out vapor like an Indonesian Volcano!
Really enjoying this rebuildable lark - I didn't think I would have the patience for it but my often hilarious noobish mistakes (trying to thread silica through a perfectly spaced, beautifully firing but stupidly fragile coil causing it to break right at the last minute - spilling e-juice everywhere more often than not - calculating the voltage so far wrong that the coil I just spent an hour on has instantaneously popped, trying to empty the kayfun by putting the drip tip over a juice a bottle and removing the base only for the drip tip to fall out into the bottle and then spending half an hour trying to get it out again) seems to keep me endlessly entertained.
There a lot to be said for humorous self-depreciation in the face of adversity when trying to stem the call of the stinkies, thats for sure.
I have a roll of .2 kanthal coming in next week hopefully. This'll do till then thanks very much![]()
Been loving mine this week - I have also been getting lots of practice in with coils! Frustrating at times agreed - Had a go with the M3 micro coils and nearly threw it against the wall.
However, .2 Kanthal with doubled 2mm Silica and 4 twists gives me a consistent and (presentable!) coil at 1.6-1.8ohm every time now! Really simple and gives a fantastic and consistent vape at 3.7V which is approx 9 watts. Takes 5 mins to do from scratch now so no problem at all. Just remember to do a good dry burn, prime with juice and have a vape through the chimney only before putting back together! This allows you to check all is good and limits rebuilding hassles if not.
Running triphammer T&H standard at 18mg through it and with the KFL+ and mini Provari I have found my vaping nirvana (For the time being!)
