*** The Official Samsung Galaxy S4 Thread ***
Kitkat is smaller than you'd think. Last rom i updated to in full was 400mb
TW Full ROM?
AOSP KK is ~ 300MB and TouchWiz KK will be ~2GB! :o
Though the OTA Update will likely be around 500MB, i.e. a lot larger than 130MB in Tysonator's update.
Atleast we agree on far later :D:D
I'm using the latest Omega ROM at the moment and I'm having lots of issues with it. Can anyone recommend an alternative?
I've been using Foxhound the last 6 months and its been very good.. I have however just made the step up to 4.4.2 and are currently testing the Echoes Rom (v14.1) and so far it seems good (just had it since last night might you).. Foxhound is more tweaked in terms of default theme, colours, etc, so I might go back to that after testing Echoes for a while.
If your phone is as bought it should just happen, a symbol appears then you press install if you want it, I won't install unless there's a fix for the non Samsung s view case issue.
Just in case you like me aren't bothered with triggering Knox (as its coming up to 1 year anyway) I can highly recommend Echoes v14.1 (Android 4.4.2).. I have used it for a couple of days now and it is GREAT.. Im coming from Foxhound, which worked fine, but Echoes seems to be even smoother and battery life is great.
Samsung's have a 2 year warranty.
Not bad.. Thats fine, I have played around with all my phones in the past and so far its all gone fine.. (probably gonna start having problems now, having said that. lol).
In which case, if you are bothered with your warranty dont install Echoes. :)
1. i need a extended battery..........I bought one and it was great even though the phone was bigger but i dropped the phone and smashed screen so........
2. i need a case and extended battery type thing. Something like that spigen case that locks around the phone would be great?
Does anything like this exist?
cheers
^ Yup spigen slim armor view, great case buuut unless Samsung sort out the chip issue the s view functionality is lost when we upgrade to 4.4, however they have a few weeks to sort the problem and it is a great protective case, I would rather not upgrade to 4.4 than change cases and I have a few spares.
what the spigen allows for extended battery?
something like this i tihink but in the uk?
http://www.amazon.com/gp/product/B0...=B00DZAXV6M&linkCode=xm2&tag=httpwwwyo0949-20
EDIT this could be it.........
[180 days warranty] ZeroLemon Samsung Galaxy S4 7500mAh Extended Battery + Free White Extended TPU Full Edge Protection Case (Compatible with AT&T I337, Verizon I545, Sprint L720, T-Mobile M919, International I9500 & I9505) ***NFC for S Beam and Google Wallet***- WORLD'S HIGHEST S4 BATTERY CAPACITY - White - (GS4-Ext-White)
Technical Details
The world's highest capacity Galaxy S4 Battery @ 7500mAh. Nearly 3 times the original capacity & slimmer than other manufacturer's extended battery
Compatible with all Galaxy S4 models. Largest Capacity Battery in the World Guarantee
Full NFC support for S Beam and Google Wallet
Black Color Full Edge Wrap TPU Case-in-One Construction built to endure hard drops & heavy shocks. No more brittle Back Covers that offers no protection to your phone
180 days Zero Lemon Guarantee Warranty with 30 days Full Refund Guarantee; Longest warranty period in market; 24 hours / 6 days a week support; 100% Zero Defect Guarantee
all for £25??
sounds like a proper case doesnt it? or am i reading it wrong?
