2014:02:05 16:33:05:362:
2014:02:05 16:33:05:363: >>> Log start
2014:02:05 16:33:05:364: Single-instance mutex has been obtained
2014:02:05 16:33:05:365: Core version: 2.5.28
2014:02:05 16:33:05:365: Setup version: 2.0.42.0
2014:02:05 16:33:05:366: Command line: "E:\SetupRST.exe"
2014:02:05 16:33:05:366: OS data: 6-1-1-1 64-bit
2014:02:05 16:33:05:367: System up time: 958 sec
2014:02:05 16:33:05:367: Reboot pending: No
2014:02:05 16:33:05:368: Current UI language: 0409
2014:02:05 16:33:05:368: Language folder: C:\Users\HOME-B~1\AppData\Local\Temp\IIFA0A2.tmp
2014:02:05 16:33:05:397: Found C:\Users\HOME-B~1\AppData\Local\Temp\IIFA0A2.tmp\ar-SA\IntelCommon.dll. Lang 0401. Rank 0
2014:02:05 16:33:05:421: Found C:\Users\HOME-B~1\AppData\Local\Temp\IIFA0A2.tmp\cs-CZ\IntelCommon.dll. Lang 0405. Rank 0
2014:02:05 16:33:05:445: Found C:\Users\HOME-B~1\AppData\Local\Temp\IIFA0A2.tmp\da-DK\IntelCommon.dll. Lang 0406. Rank 0
2014:02:05 16:33:05:470: Found C:\Users\HOME-B~1\AppData\Local\Temp\IIFA0A2.tmp\de-DE\IntelCommon.dll. Lang 0407. Rank 0
2014:02:05 16:33:05:494: Found C:\Users\HOME-B~1\AppData\Local\Temp\IIFA0A2.tmp\el-GR\IntelCommon.dll. Lang 0408. Rank 0
2014:02:05 16:33:05:518: Found C:\Users\HOME-B~1\AppData\Local\Temp\IIFA0A2.tmp\en-US\IntelCommon.dll. Lang 0409. Rank 3
2014:02:05 16:33:05:541: Found C:\Users\HOME-B~1\AppData\Local\Temp\IIFA0A2.tmp\es-ES\IntelCommon.dll. Lang 0C0A. Rank 0
2014:02:05 16:33:05:565: Found C:\Users\HOME-B~1\AppData\Local\Temp\IIFA0A2.tmp\fi-FI\IntelCommon.dll. Lang 040B. Rank 0
2014:02:05 16:33:05:589: Found C:\Users\HOME-B~1\AppData\Local\Temp\IIFA0A2.tmp\fr-FR\IntelCommon.dll. Lang 040C. Rank 0
2014:02:05 16:33:05:612: Found C:\Users\HOME-B~1\AppData\Local\Temp\IIFA0A2.tmp\he-IL\IntelCommon.dll. Lang 040D. Rank 0
2014:02:05 16:33:05:636: Found C:\Users\HOME-B~1\AppData\Local\Temp\IIFA0A2.tmp\hu-HU\IntelCommon.dll. Lang 040E. Rank 0
2014:02:05 16:33:05:659: Found C:\Users\HOME-B~1\AppData\Local\Temp\IIFA0A2.tmp\it-IT\IntelCommon.dll. Lang 0410. Rank 0
2014:02:05 16:33:05:682: Found C:\Users\HOME-B~1\AppData\Local\Temp\IIFA0A2.tmp\ja-JP\IntelCommon.dll. Lang 0411. Rank 0
2014:02:05 16:33:05:705: Found C:\Users\HOME-B~1\AppData\Local\Temp\IIFA0A2.tmp\ko-KR\IntelCommon.dll. Lang 0412. Rank 0
2014:02:05 16:33:05:729: Found C:\Users\HOME-B~1\AppData\Local\Temp\IIFA0A2.tmp\nb-NO\IntelCommon.dll. Lang 0414. Rank 0
2014:02:05 16:33:05:757: Found C:\Users\HOME-B~1\AppData\Local\Temp\IIFA0A2.tmp\nl-NL\IntelCommon.dll. Lang 0413. Rank 0
2014:02:05 16:33:05:782: Found C:\Users\HOME-B~1\AppData\Local\Temp\IIFA0A2.tmp\pl-PL\IntelCommon.dll. Lang 0415. Rank 0
2014:02:05 16:33:05:806: Found C:\Users\HOME-B~1\AppData\Local\Temp\IIFA0A2.tmp\pt-BR\IntelCommon.dll. Lang 0416. Rank 0
2014:02:05 16:33:05:830: Found C:\Users\HOME-B~1\AppData\Local\Temp\IIFA0A2.tmp\pt-PT\IntelCommon.dll. Lang 0816. Rank 0
2014:02:05 16:33:05:854: Found C:\Users\HOME-B~1\AppData\Local\Temp\IIFA0A2.tmp\ru-RU\IntelCommon.dll. Lang 0419. Rank 0
2014:02:05 16:33:05:877: Found C:\Users\HOME-B~1\AppData\Local\Temp\IIFA0A2.tmp\sv-SE\IntelCommon.dll. Lang 041D. Rank 0
2014:02:05 16:33:05:900: Found C:\Users\HOME-B~1\AppData\Local\Temp\IIFA0A2.tmp\th-TH\IntelCommon.dll. Lang 041E. Rank 0
2014:02:05 16:33:05:925: Found C:\Users\HOME-B~1\AppData\Local\Temp\IIFA0A2.tmp\tr-TR\IntelCommon.dll. Lang 041F. Rank 0
2014:02:05 16:33:05:947: Found C:\Users\HOME-B~1\AppData\Local\Temp\IIFA0A2.tmp\zh-CN\IntelCommon.dll. Lang 0804. Rank 0
2014:02:05 16:33:05:970: Found C:\Users\HOME-B~1\AppData\Local\Temp\IIFA0A2.tmp\zh-TW\IntelCommon.dll. Lang 0404. Rank 0
2014:02:05 16:33:05:974: Loading language 0409
2014:02:05 16:33:06:000: Setup mode: Installation
2014:02:05 16:33:06:001: Looking for OS: 6.1 6.2
2014:02:05 16:33:06:002: OS check passed
2014:02:05 16:33:06:002: .NET version check passed
2014:02:05 16:33:06:003: Resolving driver source
2014:02:05 16:33:06:004: Using embedded driver(s). Temp source is 'C:\Users\HOME-B~1\AppData\Local\Temp\IIFA322.tmp'
2014:02:05 16:33:06:189: Using folder 'C:\Users\HOME-B~1\AppData\Local\Temp\IIFA322.tmp' as the driver source
2014:02:05 16:33:06:189: Scanning all active devices
2014:02:05 16:33:06:282: Scanning x32\iaAHCIC.inf (Name: AHCI32, Version: 12.9.0.1001)
2014:02:05 16:33:06:283: No section match
2014:02:05 16:33:06:284: MUP OS bits: 0x92A8
2014:02:05 16:33:06:285: Scanning x32\iaStorAC.inf (Name: RAID32, Version: 12.9.0.1001)
2014:02:05 16:33:06:286: No section match
2014:02:05 16:33:06:287: MUP OS bits: 0x92A8
2014:02:05 16:33:06:289: Scanning x64\iaAHCIC.inf (Name: AHCI64, Version: 12.9.0.1001)
2014:02:05 16:33:06:289: Section with the best match: INTEL.NTamd64.5.2
2014:02:05 16:33:06:290: Device: PCI\VEN_8086&DEV_3B29&CC_0106 (Intel(R) 5 Series 4 Port SATA AHCI Controller)
2014:02:05 16:33:06:291: Device: PCI\VEN_8086&DEV_3B2F&CC_0106 (Intel(R) 5 Series 6 Port SATA AHCI Controller)
2014:02:05 16:33:06:291: Device: PCI\VEN_8086&DEV_3B22&CC_0106 (Intel(R) 5 Series/3400 Series SATA AHCI Controller)
2014:02:05 16:33:06:291: Device: PCI\VEN_8086&DEV_1C02&CC_0106 (Intel(R) Desktop/Workstation/Server Express Chipset SATA AHCI Controller)
2014:02:05 16:33:06:292: Device: PCI\VEN_8086&DEV_1C03&CC_0106 (Intel(R) Mobile Express Chipset SATA AHCI Controller)
2014:02:05 16:33:06:292: Device: PCI\VEN_8086&DEV_1D02&CC_0106 (Intel(R) C600 Series Chipset SATA AHCI Controller)
2014:02:05 16:33:06:293: Device: PCI\VEN_8086&DEV_1E02&CC_0106 (Intel(R) 7 Series/C216 Chipset Family SATA AHCI Controller)
2014:02:05 16:33:06:293: Device: PCI\VEN_8086&DEV_1E03&CC_0106 (Intel(R) 7 Series Chipset Family SATA AHCI Controller)
2014:02:05 16:33:06:294: Device: PCI\VEN_8086&DEV_8C02&CC_0106 (Intel(R) 8 Series/C220 Chipset Family SATA AHCI Controller)
2014:02:05 16:33:06:294: Device: PCI\VEN_8086&DEV_8C03&CC_0106 (Intel(R) 8 Series Chipset Family SATA AHCI Controller)
2014:02:05 16:33:06:295: Device: PCI\VEN_8086&DEV_9C02&CC_0106 (Intel(R) 8 Series/C220 Chipset Family SATA AHCI Controller)
2014:02:05 16:33:06:295: Device: PCI\VEN_8086&DEV_9C03&CC_0106 (Intel(R) 8 Series Chipset Family SATA AHCI Controller)
2014:02:05 16:33:06:296: MUP OS bits: 0x36D50
2014:02:05 16:33:06:297: Scanning x64\iaStorAC.inf (Name: RAID64, Version: 12.9.0.1001)
2014:02:05 16:33:06:298: Section with the best match: INTEL.NTamd64.5.2
2014:02:05 16:33:06:298: Device: PCI\VEN_8086&DEV_2822&CC_0104 (Intel(R) Desktop/Workstation/Server Express Chipset SATA RAID Controller)
2014:02:05 16:33:06:299: Device: PCI\VEN_8086&DEV_282A&CC_0104 (Intel(R) Mobile Express Chipset SATA RAID Controller)
2014:02:05 16:33:06:299: MUP OS bits: 0x36D50
2014:02:05 16:33:06:300: E Win32 exception occurred!!
2014:02:05 16:33:06:300: Error code: 0x4E24 (20004)
2014:02:05 16:33:06:301: Error text: ''
2014:02:05 16:33:06:301: Extended error text: 'Error in device matching'
2014:02:05 16:33:06:302: Debug info: 'Setup.cpp (229)'
2014:02:05 16:33:06:318: Showing dialog: FINISH
