Hey All
Just wanted to say a big thanks to the people helping me spec my loop and also trouble shoot a few issues I had during the install, this are now all settled and its working great. Special thanks to "Mynight" & "Avengedsevenfold" for all there persistent help.
Spec is as follows:
Case: NZXT White Phantom 820 with a NZXT 810 Side Panel (Bigger Window)
CPU: AMD FX-9370
Motherboard: ASUS SABERTOOTH AMD 990FX
Memory: 16GB Corsair Vengeance Black (4x4GB) DDR3 PC31600MHz
Graphics Card: Powercolor Radeon R9 290X OC "BF4 Edition" 4096MB GDDR5
Hard Drive 1: OCZ Solid 3 120GB 2.5" SATA-III Solid State Hard Drive
Hard Drive 2: OCZ Solid 3 60GB 2.5" SATA-III Solid State Hard Drive
Hard Drive 3: Seagate 2TB SataIII
Power Supply: 1000W Corsair RM Series 80PLUS Gold Modular Power Supply
OS: Windows 8.1
Cooling is:
CPU Block: EK Supremacy Elite AMD Full Nickel CPU Block
GPU Block: EK 290X Water Block Nickel & Acetal GPU Block & EK 290X GPU Back Plate
Top Rad: XSPC AX360 White Radiator
Bottom Rad: XSPC AX240 White Radiator
Radiator Fans: Corsair SP120 Fans x 5
Reservoir/Pump: XSPC D5 Dual Bay Res/Pump with XSPC White Faceplate
Fittings: 12 x Monsoon White Compression Fittings
Fan Controller: Bitfenix White Fan Controller
A few pics of the system being built:
And some pictures of it all running:
Spec is as follows:
CPU: AMD FX-9370
OS: Windows 8.1
Cooling is:
