- 29 Dec 2004
- Shepley
+1
If in doubt, lube.
If in doubt, lube.
Absolutely grease your pedal threads. For me a general rule is anything with a thread gets greased or copper slipped.
Yep, I pretty much grease everything. Every single bolt, headset spacers, cassette spacers, saddle rail. Pedals and brake pad cartridges are common things to get stuck.
Any tips on unstucking them? I had the little screw that holds the cartridge brake pad in place get stuck recently and just couldn't remove it no matter what i tried.
Ended up just buying another brake shoe.![]()
funnily enough the allez frame is actually a really really good frame for the price if you get a really used complete that needs new components all round, strip the frame down and get a good groupset and wheels and they're easily some of the best riding bikes around
Heads up, Garmin 800 with HR and cadence currently £234.99. Cheapest it has been a little time. Not sure I can justify the expense at the moment....maybe a credit card job?
Do it!
I'm eyeing up some Campagnolo Zondas at the moment for £283. Is there a better/lighter factory wheelset at that price?
