Oh lord, not this again.
We have got stuck in a weird paradox of what was talked about over a year ago.
Indeed.![]()
Did you read it?
from the Dev.
"They are releasing a new SDK that’s much faster and we will be comfortably running at 1080p on Xbox One".
Also, saying it will run at 60fps, case closed in this click bait title, close thread.
Also, saying it will run at 60fps.
Did you read it?
from the Dev.
from the Dev.
But a faster SDK won't make the Xbox One's that people own any faster. It's not like you can upgrade them. Although I read they are reducing the demands of Kinect to upgrade the GPU power.
basically the title is wrong it's the GPU which is making the xb1 struggle graphics wise.
the eSRAM is making it struggle even more in multi platforms because it isn't cost effective to use it properly.
this is why their is such a huge gap in multi plats, the gap should get smaller in exclusives but there will always be a gap, and a huge one in multi plats.
basically you should be buying all multi plats on ps4 if you own both consoles. if you don't know which console to choose and you care more about the multi plat titles like COD, tomb raider, fifa, BF4, etc than exclusives then get a ps4, if you care about exclusives then choose the console which you feel has the better ones to suit you.
If you are sensitive to the subject matter. It's probably best to participate in threads that won't upset you, instead of derailing an otherwise well mannered technical discussion.
Will the process become easier over time as understanding of the hardware improves? “Definitely, yeah. They are releasing a new SDK that’s much faster and we will be comfortably running at 1080p on Xbox One. We were worried six months ago and we are not anymore, it’s got better and they are quite comparable machines.
Have to agree, link and run seems to be all you are about. At least make it on topics that havent been done to death or attempt to steer it from another angle.No, your thread is ****.
You posted a link, and then a quote from the article in the OP. You've made no attempt to start of a well mannered technical discussion.
You lit the blue touch paper and stood back.
If you wanted a decent conversation on the topic why not include:
I don't believe this SDK think is going to make much difference tbh.
I'm very much inclined to agree. I'll leave this open for now in the hope it can turn into a decent discussion, but I'll be keeping an eye on it.I expect better from opening posters, if they want a particular agenda discussed then state it - dont herd peoples posts towards it and then miraculously agree once they hit on the opinion you wanted to discuss all along...
ps3ud0![]()
ps3ud0![]()
