I'm all for anything that would slightly reduce the chances of Phil Jupitus appearing on any panel show, even if it means increased chances of either Shappy Corsandy or Sara Milligan.
The female panelists they get on QI tend to be quite good for the format of the show. Sandy Toksfig (hell if I know how to spell her name ><) is always really good on it.
But in general? On the likes of Mock the Week they always seem to be there for the sake of it. They generally don't contribute anything to the random banter and some of them are really unoriginal.
Diane Morgan (Philomena Cunk from Charlie Brooker's Weekly Wipe, Dawn from Pheonix nights) is a favourite of mine atm.
I get your point. I'm saying that the research specifically states that the blind auditions accounted for 30% of the gain. Other factors such as more women applying and changes in orchestra composition accounted for the rest.
As a result, blind auditions have had a significant impact on the face of symphony orchestras. About 10 percent of orchestra members were female around 1970, compared to about 35 percent in the mid-1990s. Rouse and Goldin attribute about 30 percent of this gain to the advent of blind auditions.
Female comedians can be, and frequently are, hilarious. When doing live stand-up. The 1% that break through to TV work have traditionally not been that fantastic at moving from stage to screen when it comes to panel shows. There have been some great female sketch shows and groups for example.
The fact is, you can't just write off females as not funny based on the dozen or so that appear on TV. Once you've seen a decent amount live then you'll have a better idea. Sarah Miilican for example was a fantastic stand-up on the circuit but got all BBC-ised and mainstreamed into what is now basically a funny accent and jokes about her weight (which wasn't the case before, she was almost hot)
Yes you can (write them off)... if they can't make the transfer then they don't deserve a guaranteed place on a panel show! It should be based on merit. Next thing you know, you'll have to have a black comedian on every panel show (whilst funnier than female comedians, and I do enjoy some of them - they still tend to play the "black" card too much for my liking - but thats just preference)
no it doesn't an article says that, you've not seen the research or even if the research specifically states problem sin it's findings or any bias or discrepancies.
me thinks that the Ms Claudia and Cecilia are grinding axes.
Yep, should totes hire them based on looks. Casual sexism is fun![]()
