- 25 Mar 2004
- Fareham
Doesn't bother our dog. Hd absolutely hates the normal vacuum though!
Would you be interested in selling it?
So, my Neato Signature Pro is currently wandering around the ground floor (laminated floors) doing it's business.
Initial thoughts are that is it quieter than I expected. We have a Dyson upright vacuum and it is definitely quieter than that. It seems efficient at planning its course through the rooms and seems to cover all areas. I hadn't picked up everything off the floor when I started the cleaning, so it did manage to swallow up a Nokia charger cable and some plastic gloves, but quickly stopped and alerted me to the fact that there was something stuck in the brush.
It didn't seem to recognise the doors and moved to other rooms without finishing the first one. However, I read online that it will come back and finish it off... which it eventually did.
The only disappointment was that it doesn't clean edges as well as I would have expected. It doesn't have side brushes like the Roomba, so this probably isn't a big surprise. At least I know that the Neato will do majority of the work and I just have to go round the edges with a small handheld every now and then.
I believe The roomba shave the best vacum part but the neato's algorithms are better for a consistent coverage. Roomba' sues a more stochastic random walk effect with some spiral and edge detection, Neato's do have a basic mapping algorithm that often works better but can make bigger mistakes. The roomba will always clean everywhere due to its random walk, but it might take significantly longer. The upshot is the roomba will cover the same areas multiple times improving the clean but taking longer to get the job done.
It is also possible to reprogram the roomba., which is why I got one. We used roombas for course work in some of the robotics classes I taught.
today a valuable lesson has been learned
If your dog does a small mistake while you are out.
Roomba will not go around said mistake.
messy
messy
Well, with my Roomba being such a big success I now want to try out a floor mopping solution to give my floors a good go-over... and due to the fact that I haven't mopped my apartment since I moved in. Over a year ago. Ahem.
I saw the iRobot Braava series gets good reviews, and I can get the 380 model for £205 where I live. Here's the info page http://store.irobot.com/product/index.jsp?productId=22181696#showReviews
Anyone else used one?![]()
I was looking at Robots for hard floors but was leaning towards the Scooba as it also scrubs.
We find at the moment we have to sweep the floor before we mop to do a full proper clean.
