Gaming PC upgrade advice needed
I was under the impression that an 8 pin plug would work fine in a 6 pin socket, as they are 'keyed'. Just as you can use an 8 pin eps cable in a 4 pin atx socket.
Otherwise what would be the point of a 6+2 cable ?
It will, as long as it splits, but the OP does`nt have another 8 pin(6+2) or a 6 pin.
Hey, bumping the thread here. I have kept my same PSU, but recently got a radeon r9 270x from overclockers, but my current graphics card uses one 'pci' 6 pin power cable from my psu. Looks like the r9 needs 2 x 6 pin cables, but there is only one 6-pin pci output from the PSU. There is 2 unused SATA 6 pin connections or another pci connection but it is 8 pins, can I use either of these from my PSU to connect to my new graphics card?
I read it that the psu had a 6pin and a 8 pin :confused:
