- 15 May 2012
- Louth, lincs
When you contact them petey make sure you email and not use the contact form, the forms are for general enquiries and get lost!!
yep, my 1080 is semi-retired atm, had to downsize to an H2
Word of advise, if using a mahoosive rad (1080/1260) do your self a favour and run a couple of high pressure pumps in series on the loop, will literally save you hours bleeding it.
If you want silence on those 180mm's I can highly recommend the Phobya G-Silent 18 700's, dirt cheap too!
Gonna have to make do with a single D5 and see how it goes for now.
Those are the fans I went for actually![]()
