See you're missing the point. How do you know he wasn't only referring to performace of the machine itself? You're presuming he was talking about other/all factors.
I'm not missing the point, he was just talking about performance, but that isn't the only factor, hence why I contested his point that they are on *a* level playing field.
The performance variable doesn't matter with regards to a level playing field because there are other factors which I have mentioned.
I am not presuming he was talking about others/all factors, I am pointing out that he has ignored those factors to get to the conclusion that it's a level playing field.
Also;
I used to be a heavy pc gamer and I'm aware of what can be done to make your opponent easier to see etc.
I disagree with your comments regarding consoles, you can't turn anything down, or up, or anything of the sort, so in that respect I don't understand how you can say that they are not on a more level playing field than a pc.
This is the part where you're arguing against something I didn't say. I haven't said that consoles aren't on a more level playing field than PCs when you're talking about performance only, despite how irrelevant there typically will never be a situation where it's only performance that is a factor.
