- 25 Apr 2010
- Ipswich
Blimey where to start.
1. Did you update your motherboard bios to the latest version?
2. Update afterburner. The version you're using is older than Jesus H Christ.
3. Once the new version is installed, disable ULPS in settings. Its a nice power saving feature but unless you're worried about that its better to disable it and get a few percent extra performance.
4. Set the power limit at +50% and away you go.
On and btw, crossfire only works in full screen mode. See this thread to setup some overlays to monitor performance in game.
Will try this bud thanks
You have any idea on the gpu usage however?
