Here is Guru3D's power supply recommendation:
Sound advice.
- GeForce GTX 780 - On your average system the card requires you to have a 550 Watt power supply unit.
- GeForce GTX 780 2-way SLI - On your average system the cards require you to have a 800 Watt power supply unit as *minimum.*
- GeForce GTX 780 3-way SLI - On your average system the cards require you to have a 1200 Watt power supply unit as *minimum.*
Sound advice.
